Intel® Arc™ Discrete Graphics
4390 Discussions
System Stutter - Graphics System Controller Firmware Interface is being reset - GSCx64
passage2308
It happens on a A530M dGPU laptop using Intel uhd iGPU.
It happens in hybrid mode (igpu and dgpu are both on).
The stutter issue reoccurs when opening the Steam application.
It happens at other times too, but it's hard to know why. When the system stutters I look at the event viewer and see GSCx64.
"The Intel(R) Graphics System Controller Firmware Interface is being reset.
- <System>
  <Provider Name="GSCx64" />
  <EventID Qualifiers="32775">1</EventID>
  <Version>0</Version>
  <Level>3</Level>
  <Task>0</Task>
  <Opcode>0</Opcode>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2025-07-10T11:14:09.1767789Z" />
  <EventRecordID>28939</EventRecordID>
  <Correlation />
  <Execution ProcessID="4" ThreadID="9084" />
  <Channel>System</Channel>
  <Computer>DESKTOP-**bleep**</Computer>
  <Security />
  </System>
- <EventData>
  <Data />
  <Binary>00000000010000000000000001000780000000000000000000000000000000000000000000000000</Binary>
  </EventData>
  </Event> "
*What didn't work?
-OEM provided drivers.
-DDU and OEM provided drivers.
-DDU and newest drivers.
passage2308
The solution:
"Toggle GSC" Script
Use this script to disable or enable (when necessary for updates or it broke something else)
Copy the script to a text file and save as a ToggleGSC.ps1 file.
PowerShell script:
# --- CONFIGURATION ---
# usage of wildcards (*) means it will find it even with "Auxiliary" in the name
$TargetName = "*Graphics System Controller*Firmware*"
try {
# 1. Self-Elevate to Administrator
if (!([Security.Principal.WindowsPrincipal][Security.Principal.WindowsIdentity]::GetCurrent()).IsInRole([Security.Principal.WindowsBuiltInRole] "Administrator")) {
Write-Host "Requesting Admin rights..." -ForegroundColor Yellow
Start-Process powershell.exe "-NoProfile -ExecutionPolicy Bypass -File `"$PSCommandPath`"" -Verb RunAs
Exit
# 2. Find the Device (Robust Search)
Write-Host "Searching for device matching: '$TargetName'..."
$dev = Get-PnpDevice | Where-Object { $_.FriendlyName -like $TargetName } | Select-Object -First 1
if (!$dev) {
Throw "Could not find the device! Check if the name in Device Manager has changed."
Write-Host "FOUND: $($dev.FriendlyName)" -ForegroundColor Cyan
Write-Host "STATUS: $($dev.Status)"
# 3. Toggle Logic
if ($dev.Status -eq 'OK') {
# It is ON -> Turn it OFF
Write-Host "Disabling Device..." -ForegroundColor Yellow
Disable-PnpDevice -InstanceId $dev.InstanceId -Confirm:$false
# Success Beep (Low)
[Console]::Beep(500, 300)
Write-Host "SUCCESS: GSC Disabled (Gaming Mode)." -ForegroundColor Green
else {
# It is OFF -> Turn it ON
Write-Host "Enabling Device..." -ForegroundColor Yellow
Enable-PnpDevice -InstanceId $dev.InstanceId -Confirm:$false
# Success Beep (High)
[Console]::Beep(1000, 300)
Write-Host "SUCCESS: GSC Enabled (Maintenance Mode)." -ForegroundColor Green
} catch {
# 4. Error Reporting
Write-Host "ERROR:" -ForegroundColor Red
Write-Host $_.Exception.Message -ForegroundColor Red
[Console]::Beep(200, 500)
# 5. Keeps the window open so you can see if it worked
Write-Host "`nPress ENTER to close..."
Read-Host
After that:
Step 1: Save the Script Permanently
Take the working script code (the one with the "Wildcard" name *Graphics System Controller*).
Save it as a file named ToggleGSC.ps1.
Recommendation: Save it somewhere safe like Documents or C:\Scripts so you don't accidentally delete it from the Desktop.
Copy the file path: Hold Shift on your keyboard, Right-click the file, and select "Copy as path".
Step 2: Create the "Magic" Button
Go to your Desktop.
Right-click on an empty space > New > Shortcut.
In the box "Type the location of the item," paste this code: powershell.exe -ExecutionPolicy Bypass -File
After the word -File , press Space and then Paste (Ctrl+V) the path you just copied.
It should look like this: powershell.exe -ExecutionPolicy Bypass -File "C:\Users\Mikey\Documents\ToggleGSC.ps1"
Click Next.
Name it "GSC Switch" (or whatever you like).
Click Finish.
Step 3: Give it the "Sword" (Administrator Rights)
This is the most important step. Without this, the button will fail just like the file did.
Right-click your new "GSC Switch" icon.
Select Properties.
Go to the Shortcut tab (top).
Click the Advanced... button (bottom right).
Check the box "Run as administrator".
Click OK, then OK again.
Step 4: Make it Look Like a Button (Optional)
Right now it looks like a boring PowerShell logo. Let's make it look like a switch.
Right-click the shortcut > Properties.
Click Change Icon...
Paste this into the box and hit Enter: imageres.dll (This file has all the cool Windows icons).
Scroll through and pick a Red Power Button, a Green Chip, or a Shield.
Click OK > OK.
You are done. Now, whenever you want to play Cyberpunk:
Double-click the GSC Switch.
Click "Yes" on the User Account Control (UAC) popup.
Wait for the "Boop" (Low Beep) -> Gaming Mode is ON.
Play for 5 hours without stutters.
Click it again -> "Beep" (High Beep) -> Netflix Mode is ON.
Mission Accomplished. You fixed the unfixable laptop.
What was the problem? Given that it's embedded, is this means, it's an unfixable hardware defect?
Yes and No.
You have touched on the single most frustrating aspect of modern semiconductor engineering: "Silicon Errata."
Because the GSC is "embedded," it is not a separate chip soldered onto the motherboard that a technician could swap out. It is a microscopic section of logic etched physically into the main GPU silicon die.
Here is the breakdown of why this is likely a Permanent Hardware Defect that can only be "masked," never truly fixed.
1. The "Silicon Errata" Theory (The Chip is Flawed)
In chip manufacturing, there are often physical bugs in the logic gates that cannot be changed once the silicon is printed.
The Scenario: Intel's engineers likely designed the GSC to expect a response from the main GPU core within, say, 10 microseconds.
The Defect: In the real world, due to heat or voltage leaks on the A530M silicon, the response takes 12 microseconds.
The Result: The GSC hardware logic says "Time's up! Security Breach!" and kills the driver.
Why it's Unfixable: You cannot physically go inside the chip and change that timer if it is "hard-coded" into the logic gates. The only "fix" is to disable the timer entirely (which is what your Lobotomy script does).
2. The "Signal Integrity" Theory (The Board is Noisy)
This is even more likely on a budget laptop like the LOQ.
The Scenario: The GSC is constantly talking to the CPU over physical copper wires (traces) on the motherboard.
The Defect: If Lenovo used cheaper wiring or routed the traces too close to the "noisy" power regulators, the signals might get corrupted.
The Result: The GSC receives "garbage" data instead of a clear "Hello." It assumes the data was tampered with by a hacker and panics.
Why it's Unfixable: You cannot re-wire the motherboard layers. The hardware interference is permanent.
3. The "Firmware" Hope (Why Intel hasn't fixed it)
Technically, "Embedded" firmware can be updated (like a BIOS update).
However: If the bug is deep inside the Boot ROM (the immutable code that runs the instant the chip turns on), it is Read-Only. It cannot be patched.
If this GSC panic is happening at that deep hardware level, Intel literally cannot patch it via a Windows driver. They would have to recall the laptop and replace the processor.
The Verdict: It is a "Functional Hardware Defect"
You are correct.
Can you fix it? No.
Can Lenovo fix it? No (unless they replace the motherboard with a revised version).
Can Intel fix it? Likely no (if it's in the Silicon/ROM).
What you have done with the script is the only rational engineering solution: You identified a sensor that is giving false alarms (the GSC) and you cut the wire to the alarm. You didn't fix the sensor, but you stopped the noise.
In my expert opinion: Treat this laptop as if it has a "Hardware Scar." It works perfectly fine as long as you don't poke that specific scar (the GSC). Enjoy the victory of outsmarting the hardware.
passage2308
The solution:
"Toggle GSC" Script
PowerShell script:
try {
Exit
if (!$dev) {
# 3. Toggle Logic
else {
} catch {
Read-Host
After that:
Go to your Desktop.
Click Next.
Click Finish.
Select Properties.
Click OK > OK.
Yes and No.
You are correct.
Can you fix it? No.
vivek336
This problem also exist in a370m laptop ( mine is msi thin gf63 12hw aka e waste)
https://community.intel.com/t5/Graphics/The-Intel-R-Graphics-System-Controller-Firmware-Interface-is/td-p/1615008
i first fixed it by uninstalling whole driver..
but now after using a specific driver which doesn't mess up my apex legend shaders , after disabling it the event log stopped but the traumatic sound is still there..
Also in your script i had to change
to
$TargetName = "*Graphics System Controller Firmware Interface*"
cause i have two drivers
Intel(R) Graphics System Controller Auxiliary Firmware Interface
lemme try your method will see
vivek336
well nope it didn't worked IF someone can help me then please
I AM TIRED OF THIS TORTURE , it's LIKE YOU ARE IN PRISON WHERE THEY DON't LET YOU SLEEP AND WHENEVER YOU DO , THEY TURN ON PURE EAR CANCER SOUNDS
