Intel® Arc™ Discrete Graphics
4412 Discussions
Using ARC A750 in VR?
ericcarm
Hey there! Should I even expect support for Vive stuff at the moment? We just swapped out a 1060 for an A750, changed nothing else about the setup, and we cannot boot into SteamVR any more. It says it can't find the headset -- everyone else getting same problem with latest drivers?
Error message is "Your graphics card cannot successfully connect to your HMD display"
powerarmour
Valued Contributor II
Yes this is a known issue unfortunately, there's a bug report on the GitHub here: https://github.com/IGCIT/Intel-GPU-Community-Issue-Tracker-IGCIT/issues/184
ericcarm
All good, I can be patient for a while waiting for Intel to get stronger drivers
Thanks a ton for the github issue I can track, appreciate it.
Saabjock
After months of inactivity, I just installed my HP Reverb G2 on my newly acquired A770-16 and it works.
Like the OP, I too went from a GTX1060-6 to the A770 card.
I am using the newest BETA driver.
The Cliff house images do look worse with the A770 than it did with the GTX1060.
Standing on the edge of the terrace and looking down at the ocean below, you are presented with just blue banding....no flowing waves like the GTX1060.
It is a significant loss of visual effect.
Hopefully the continuation of driver development will fix that.
Intel(R) Graphics Driver: 31.0.101.3975
Intel(R) Display Audio Driver: 11.2.0.10
Intel(R) Display Audio Driver: 12.1.0.9
Build Date: December 09, 2022
Hugo_Intel
Hello ericcarm
Thank you for posting on the Intel® ARC™ Graphics Communities. I am sorry to hear that you are experiencing issues trying to use VR on your Intel® Arc™ A750.
If I may jump into the conversations we want to let you know that Intel Arc graphics support for VR headsets continues to evolve as we ramp our products and add updates to our software stack. We appreciate your patience.
Hugo O.
Hugo_Intel
Hello ericcarm
I hope you are doing fine.
Were you able to check the previous post?
Let us know if you still need assistance.
Best regards,
Hugo O.
Intel Customer Support Technician.
Hugo_Intel
Hello ericcarm
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
ericcarm
Sorry, just now seeing this!
Tried with this driver:
 - Date: 3/16/2023
 - Version: 31.0.101.4148 (Latest)
Same error. I went and downloaded and set up everything to test this again -- was something changed? I checked the drivers pretty regularly and didn't see anything about VR?
