Intel® Arc™ Discrete Graphics
4130 Discussions
Visual Artifacts on chrome
Stormtrooper
Hello. Whenever i´m using chrome with my asrock b580 challenger, i get some artifacts on the buttons to minimize and maximize the screen if i pass the mouse close to them. If i disable hardware acceleration it stop from happening. This does not happend with my previous gpu. I have tested 3 or 4 versions of the drivers but it happens with all of them. The rest of my system is windows 11 with a ryzen 5 5600x cpu and 32 gb of memory.
Thanks in advance for your help on this. Its nothing serious, but its annoying as hell
VonM_Intel
Hello Stormtrooper,
Zalim
Hello Von M.
Why create similar threads if the problem is the same?
I think that's why this site exists as a forum, so people can share their thoughts with each other and with you.
Isn't that right?
Zalim
ArchieD_Intel
Hello Stormtrooper,
I will be looking further into this issue and will update you as soon as possible.
Hi Zalim, thank you for contributing to the discussion. While community members are welcome to share their experiences, I'd kindly recommend creating a separate thread for your specific issue. This allows us to provide focused assistance tailored to your unique system configuration, as different setups may require different troubleshooting approaches.
Thank you for your cooperation and understanding.
Archie D.
gasoline
Valued Contributor I
With the latest driver 8626, everything is the same, nothing has changed.
Stormtrooper
Yes. With mine too. The problem remains, unfortunately.
George_Intel
Hello Stormtrooper and other community members,
I will be providing support for this issue moving forward. I have been able to replicate the issue consistently on the latest drivers as well.
The issue has been escalated and I will keep you posted on any updates.
gasoline
There is still no solution to the problem.
George_Intel
Hello gasoline,
You are correct, the issue is still under investigation to determine the root cause.
Appreciate your continued patience.
George
gasoline
Excellent, George.
Thanks for your reply.
When you remain silent, we don't understand what's going on.
Is anyone addressing this issue?
But after receiving a response, it becomes clear that the investigation is ongoing.
George_Intel
Thank you gasoline for your feedback.
I will keep this thread posted on any updates, when they are available.
George
Stormtrooper
George_Intel
Hello @Stormtrooper ,
Just letting you know that there are no updates, but I will continue to keep you apprised if anything changes.
Thank you for your continued patience
George
Stormtrooper
Thanks one more time for keep us updated
