Intel® Arc™ Discrete Graphics
3544 Discussions
When using an Arc graphics card to play Delta Force, the thermal imaging sight fails to display pro
zhi997
系统: Windows 11 Pro 64 位,版本 22631.5335 (23H2)
处理器: 英特尔酷睿 i5-12600KF
显卡:Intel Arc A770 (Acer)
主板: MS-Terminator B760M (Maxsun)
硬盘:KIOXIA EXCERIA PLUS G3 SSD
记忆:SK 海力士 DDR4-4000 (2000 MHz),16GB × 2
游戏中的热成像瞄准器无法显示场景细节。
左边QQ截图20250606174526.jpg是 A770,右边是 NVIDIA 4060 Ti。
Mike_Intel
Hello zhi997,
  1. Was it working fine before?
  2. What was the last change made before the issue started?
  3. What are the troubleshooting steps that you tried so far?
Michael L.
erep
hello, i have same issue here where i tried using my gpu which intel arc b580 i cant see the environment thru the thermal scope, but when i switch the graphic setting using my IGPU from amd ryzen 5 7600x the problem solved. what can i do? i tried to reinstall older driver but nothing works
using igpu from my processor (AMD)using igpu from my processor (AMD)
using intel arc b580using intel arc b580
zhi997
你好 Michael L.
当我开始使用这个显卡玩这个游戏时,这个问题一直存在。
我尝试更换驱动程序,但没有 work.
我咨询过中国的游戏社区,他们告诉我,当他们使用 Intel GPU 时,也会出现同样的情况
Mike_Intel
Hello zhi997,
Thank you for the update.
For me to further check this issue, please help generate the SSU logs of your system. Kindly refer to the link below on how to generate the logs:
@erep
If you need assistance, please create a new thread for us to assist you on your own thread and gather the details of your systems.
Michael L.
zhi997
Hello Michael,
Thank you for your continued support.
Please let me know if you need anything else.
Thanks again.
erep
where can i send this SSU logs file for you? i just put here on the reply?
erep
okay i just put here, thank you
Mike_Intel
Hello zhi997,
Upon checking your SSU, you are using graphics driver version 32.0.101.6874.
The latest that we have is version 32.0.101.6881.
Please try to install the latest driver using DDU method.
Kindly refer to the links below on where to download the latest driver and steps for DDU method.
Intel® Arc™ & Iris® Xe Graphics - Windows*
How to Use the Display Driver Uninstaller (DDU) to Uninstall an...
Michael L.
zhi997
Hello Michael,
Mike_Intel
Hello zhi997,
Let me gather the following details for documentation.
  1. What is your game launcher? Are you using Steam, Epic Games?
  2. Aside from the Thermal imaging site, are you having other issued on this game?
Michael L.
zhi997
Hello Michael,
I use Tencent's WeGame in China to launch this game, but this problem also occurs when using Steam.
I haven't found any other issues except for the thermal imaging.
Appreciate your time and support.
Zhi
Mike_Intel
Hello zhi997,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
Hello zhi997,
I just want to update you that I am now trying to perform simulation for this issue.
And to do that, I am requesting a screenshot of the Graphics settings in English for me to follow.
Michael L.
zhi997
Hello Michael,
I am very sorry.
I haven't found the language option in the game due to the issue with my game version.
I can only provide you with a screenshot of the Chinese settings. I hope it can help you.But I have tried changing the in-game settings before, and this issue still cannot be resolved.
屏幕截图 2025-06-19 184623.jpg屏幕截图 2025-06-19 184645.jpg屏幕截图 2025-06-19 184704.jpg
Mike_Intel
Hello zhi997,
I am really sorry; I am going to use the screenshot of the settings for me to simulate the game in our lab.
I hope you can still provide the game settings in English for me to simulate this issue accurately.
Michael L.
zhi997
Hello Michael,
I hope these can help you.屏幕截图 2025-06-20 202938.jpg屏幕截图 2025-06-20 202950.jpg屏幕截图 2025-06-20 202957.jpg
Mike_Intel
Hello zhi997,
Thank you for the screenshots.
Let me continue to check this issue and post the response on this thread once it is available.
Michael L.
Mike_Intel
Hello zhi997,
 Based on my latest simulation investigation indicates that graphics driver version 32.0.101.6913 WHQL Certified (Latest) appears to have resolved the issue. We recommend performing a clean installation using DDU and then installing graphics driver version 32.0.101.6913 WHQL Certified (Latest). Once done, please update this thread if the latest driver was able to fix the issue.
Michael L.
Mike_Intel
Hello zhi997,
I am just checking if you tried my last recommendations.
Michael L.
zhi997
Hello Michael,
I have installed 6913 and the issue has been resolved.
Thank you very much.
