Intel® Arc™ Discrete Graphics
Zenless Zone Zero
AsterCrash
Hi, good evening. I'm having performance issues with ZZZ. Attached are the CapFrameX and SSU results.
I'm using 1080p and all settings are at the highest possible level. I believe the B580 should be performing well above the FPS shown in CapFrameX.
Jay_Intel
Hi AsterCrash,
  1. Does the issue occur only during cutscenes? Or does it also happen during regular gameplay or menus?
  2. When did the issue start? Was it after a specific driver update or game patch?
  3. What are the troubleshooting steps that you tried so far?
  4. Have you used Display Driver Uninstaller (DDU) to completely remove all residual drivers and installed a new one?
  5. Have you tried adjusting the graphics settings?
  6. Could you provide a screenshot of your in-game display and graphics settings?
  7. Which gaming platform did you use to download the game?
the CapFrameX log you provided was less than a minute and I would like to obtain 3 more copies of CapFrameX log to thoroughly analyze the FPS performance. Kindly ensure that the game would run for a minimum of 3 minutes each.
Louie Jay J.
Jay_Intel
Hi AsterCrash
Additionally, there is a new driver version available 32.0.101.8824, have you tested this version to check if the issue still persists?
Louie Jay J.
Jay_Intel
Hi AsterCrash
Louie Jay J.
