Intel® Arc™ Discrete Graphics
3512 讨论
arc a750 hangs on post
cabbose2552
初学者
1,927 次查看
my sparkle titan oc a750 is hanging on post, I have a 500w PSU but it has booted before on it. other GPUs (1650, 960) work on the system. when the primary display is set to integrated graphics it will show a white under score on a frozen screen; when set to auto it shows a black screen. I have tried disabling igpu mulimonitor and different ram.
board:ASRock h470m-hvs
GPU:sparkle titan oc a750
CPU:i3 10100
RAM:64gb g.skill ripjaws
0 项奖励
3 回复数
Hugo_Intel
员工
1,886 次查看
Hello cabbose2552
Thank you for posting on the Intel® ARC™ Graphics Communities.
In this case, we recommend using a 600W PSU as a minimum even though your configurations have worked before it would be better to test the GPU on a system that meets the requirements to make sure it receives the needed power for it to function properly.
I would also recommend testing different cables to discard possible damaged cables, if the issue persists, please share with us the following information:
  • What type of connections are you using(HDMI, DP)?
  • Are you using any type of video adapter?
  • Create and share with us a log file from the Intel® System Support Utility to get more detailed information on your hardware and driver details.
Hugo O.
0 项奖励
Hugo_Intel
员工
1,829 次查看
Hello cabbose2552
Have you been able to re-test your GPU in a different PSU? If the issue still continues or not possible for you to test another PSU let us know the information we requested in our previous post.
Hugo O.
0 项奖励
Hugo_Intel
员工
1,781 次查看
Hello cabbose2552
We have not received a response from you so we will proceed to close this thread. If you are still experiencing boot issues after testing a 600W power supply or different cables, feel free to open a new topic so we can assist.
Hugo O.
0 项奖励
回复
