Intel® Arc™ Discrete Graphics
dota2 B580
Royalseries
  • In Dota 2, my FPS is barely hitting 100 or even lower.
  • What’s shocking is that my previous older graphics card actually gave me much higher FPS on the same settings.
  • I’ve tried tweaking in-game graphics, updating drivers, and checking temps – but the performance is still underwhelming.
Has anyone else faced this issue? Could this be a driver optimization problem, BIOS setting, or others?
i  have make sure that my rebar setting is on.
VonM_Intel
Hi Royalseries,
Thank you for posting in our Community and for sharing the details about your FPS issue in Dota 2 with the Intel Arc B580.
To assist you better, could you please provide some additional information?
  1. Which older graphics card were you using before the B580?
  2. What CPU and RAM are you running alongside the B580?
  3. Are you running the latest BIOS version and chipset drivers on your system?
  4. Could you share the exact driver version currently installed for the Intel Arc B580?
  5. Have you tried running any other games or benchmarks to see if the low FPS issue is specific to Dota 2 or affects other titles as well?
  6. Are there any background applications that might be impacting performance during gameplay?
  7. Could you confirm your in-game graphics settings and resolution?
Additionally, I'd like to delve deeper and verify specifics like the graphics models, precise driver versions, and any system errors. Utilizing the Intel SSU tool will enable me to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue. Once we have this info, we can better determine if it’s related to driver optimization, BIOS settings, or something else.
Have a nice day!
Von M.
VonM_Intel
Hello Royalseries,
Von M.
PatrickV_Intel
Hi Royalseries,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Patrick V.
