Intel® Arc™ Discrete Graphics
3510 Discussions
>observer_ crashes after few minutes of game (A770)
Roflosaur
>observer_ crashes after two or three minutes on start location. On older drivers also crashes.
CPU: 12th Gen Intel(R) Core(TM) i5-12400F 2.50 GHz
RAM: 32,0 Gb
GPU: Intel Arc A770 16 Gb
OS: Windows 10 2H22 build 19045.2965
Driver version: 31.0.101.4952
Andres_Intel
Hello Roflosaur,
Thank you for posting on the Intel communities. I see that >observer_ crashes with your Intel® Arc™ A770 Graphics after you play for some minutes, I will be more than happy to help you.
To understand this issue in a better way, please answer the following questions:
Andres P.
Roflosaur
1.Steam
2.Video in attach (.mkv in archive). Long black screen between cutscenes is  freeze the game, and then crash.
3.Just "program stop"
4. SSU log in attach
Andres_Intel
Hello Roflosaur,
Thank you for your response and for providing the information.
I have checked the Intel® SSU report, and I noticed there are some updates to make, that may help to try to solve this issue:
Andres P.
Roflosaur
I appreciate the prompt support. But you really recommend me a risky operation that can kill my motherboard just for (probably) decide your card problems, and then recommend re-install latest driver that already installed?
Andres_Intel
Hello Roflosaur,
Thank you for your answer.
The reason why we recommend having the BIOS updated is because these kinds of updates have improvements in stability and compatibility, which may help to try to solve this issue. We always recommend having the system up to date for a better performance of the graphics card. My advice for a proper installation of the BIOS and to avoid future problems is to contact MSI for guidance.
Related to the graphics driver update I am aware that you have already installed the latest version, but before an installation we recommend clean installing the current version with DDU, if you have already done that with version 31.0.101.4952, you do not have to do it twice, but if you have not done that yet, remember to follow the article How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver, this is important to do it because in some case with this simple step the behavior of the graphics card changes.
Please keep me informed of the results
Andres P.
Roflosaur
It was nervous a little, especially when after installing BIOS settings didn't save, but turning off the battery was help. So, BIOS is "2.D0, ALASKA - 1072009" (7D24v2D) now. Driver version is 4925 (latest). Game is still crashes. As I see, it's do it anyway, just standing in main menu, for example.
Andres_Intel
Hello Roflosaur,
Thank you for your reply and for completing the steps.
I will start with an investigation to provide you with the next steps as soon as possible.
Andres P.
Andres_Intel
Hello Roflosaur,
Thank you for your patience.
We were going to start with the replication, but we noticed >observer_ is no longer available for purchase at Steam, instead, it is now Observer: System Redux. Does the issue occur on this new game version?
Andres P.
Roflosaur
I don't know because I have no that version of game.
Andres_Intel
Hello Roflosaur,
Thank you for your clarification.
I will continue with the investigation to provide you with the next steps as soon as possible.
Andres P.
Andres_Intel
Hello Roflosaur,
Thank you for your time.
I have been working on the investigation and now we will start with the replication of the issue, and as soon I have the results I will let you know.
We appreciate your patience.
Andres P.
Andres_Intel
Hello Roflosaur,
We have been working on the replication of the issue, and we hope to have the results soon, as soon as I have them I will let you know.
Andres P.
Andres_Intel
Hello Roflosaur,
Thank you for all your time.
We have been working on the reproduction of the issue, but we were unable to replicate it. Since the >observer_ game version no longer has public distribution we completed the reproduction with the game version Observer: System Redux. Our recommendation is to use the new version only.
Let me know if you have further questions about it.
Andres P.
Andres_Intel
Hello Roflosaur,
I just want to remind you that we were unable to replicate the issue. Since the >observer_ game version no longer has public distribution, we completed the reproduction with the game version Observer: System Redux and our recommendation is to use the new version only.
Andres P.
Andres_Intel
Hello Roflosaur,
Andres P.
