Hello Intel Support!
So i use Intel Arc A380 for [CINEMA 4D 2025.1.1] it seemed fine with that Version, until i updated my graphics display driver from [32.0.101.8331] to --> [32.0.101.8509] WHQL certified.
My CINEMA 4D's viewport seem to have weird flickering glitches.
i have even given a screen recording of the issue.
Rexfrese
Hello Rexfres,
- Kindly tell me how you updated the driver.
- What will happen if you rollback the driver?
- What are the troubleshooting steps that you tried so far?
- For me to review the hardware and the driver installed, please help generate the SSU logs of your system. Kindly refer to the link below for the steps:
Michael L.
Hello Rexfres,
Michael L.
Hello Intel Support,
1. I updated the drivers through [Intel® Graphics Software]
2. I'm not sure what will happen but i updated my drivers if any chance i get any issue with older display drivers. I would roll back but i often get random flickerings so i thought it would fix it with the latest driver [32.0.101.8509] WHQL Certified.
3. I haven't tried anything so far as i know nothing would help out.
4. i have attached the txt file. Please check it.
And, i would like to state another fact that my VEGAS PRO 23 has stopped working.
Should i wait for new driver update or should i roll back to my previous one?
i have finally tried everything and figured it out it seem nothing wouldn't work properly with the new driver. I wanted to select it as "Accept as solution" but i still want Intel Support's Feedbacks regarding about my issue.
Rexfrese
Hello Rexfres,
Thank you for the update.
Upon initial checking of your SSU logs, I found out that the BIOS of your board is not updated. As per the link of the manufacturer of the motherboard, they encourage their users to update to the latest due to vulnerabilities. We are not sure if this is the cause of the issue that you encounter. Here is the link:
B365M GAMING HD (Rev. 1.0) - GIGABYTE Global
As for the Intel Arc, please try to install the latest driver using DDU. Kindly refer to the link below for the steps and direct link of the latest driver
How to Use the Display Driver Uninstaller (DDU) to Uninstall a...
Intel® Arc™ Graphics - Windows*
Michael L.
Hello Rexfres,
Michael L.
Hello Rexfres,
I am sending another follow up to check if you tried my last recommendation. If you need assistance in updating the BIOS, please contact the manufacturer of the motherboard for assistance since different boards may have different steps.
Michael L.
