Intel® Arc™ Discrete Graphics
4395 Discussions
low gpu usage and fps drops
GOLAMHABIB
i had faulty a750 but later i got it replace . the new one has give me way better  fps in bench marks.
but what ever game i play the gpu usage is below 80%
like in spider man remaster usage is below 50%
delta force is like 50-70%
I watched few videos on youtube then change few settings in Windows like hardware acceleration turned on ultimate performance and few other
these improved my 1% lows fps by a lot and my fps also but fps is still very unstable and bit of fps drops
the a750 can deliver more fps as my gpu usage low
in delta i am geting up down of 100-130fps
so my problem how to fix my fps drop and low gpu usage.
ssu and a cap framex gameplay is attached of delta force all low setting and intel xess balanced
also i play with all core
i have done ddu installation
rebar enabled
Mike_Intel
Hello GOLAMHABIB,
  1. Are you using an Intel brand Arc A750?
  2. What is the specification of your power supply?
  3. Did you change any settings or are you using default settings?
Michael L.
Mike_Intel
Hello GOLAMHABIB,
Michael L.
GOLAMHABIB
my prob lem is now solved it was input lag I have 60hz monitor 5ms this my temporary monitor an d also my ups was old 300w
but still I have another prob now every thing just happens to me worst  luck . now the intel graphics driver is giving me prob it is not showing tuning section now . after again did ddu I also installed the driver with repair does not work . also every time I have end task in task manger . its is also not enabled as startup . what should I do now ?
i have worst luck possible
RandyT_Intel
Hello GOLAMHABIB,
Regarding the tuning utility on the Intel Graphics Software, for now, you can use "Performance -> Metrics" from IGS. We are currently working to include this feature in our future release.
For the startup concern, have you checked the system settings to ensure the software is enabled during startup or system launch?
Randy T
Mike_Intel
Hello GOLAMHABIB,
Just sending a follow up on the question that we asked in our previous post.
Michael L.
Mike_Intel
Hello GOLAMHABIB,
I am sending another follow up on the information that I requested.
Michael L.
