Intel® Arc™ Discrete Graphics
moniter truble
hicks
In a dual-monitor Windows 11 setup using both DP and HDMI ports, when a monitor is turned off and then back on, the HDMI-connected monitor displays 'No Signal' and the system reverts to a single-monitor environment. This issue persists, requiring a complete power cycle and reboot to re-recognize the monitor
AlfredoS_Intel
Hi Hicks,
Kindly provide the following information, so we can prepare a list of viable suggestions for you to do:
1. It would really help us if we can get more information about your system. Please download and run our Intel® System Support Utility from this page. To run it, please press "Scan". After the scan is finished, click next and there will be a save button, giving you an option to save the logs to a text file, please do so and attach the file on your reply. You can refer to How to get the Intel® System Support Utility Logs on Windows* for instructions.
2. Did you observe this behavior since day one?
3. Do you have a hub where both the monitors connect to or it is a straight connection to the ports on your system?
Alfred S
AlfredoS_Intel
Hi Hicks,
I wanted to check if you had the chance to read the questions that we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Alfred S
AlfredoS_Intel
Hi Hicks,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment. We know that this is important for you to get it resolved and it is also equally important for us to give you the right solution; as much as we would like to assist you, we need to close it to attend to other customers.
We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
