Intel® Arc™ Discrete Graphics
roblem install
ALAK
Hi mate ihave problem after last update i cant install inte grapichs software i need help
Lowroen
Dude, you downloaded the driver
extract to folder-Resources-Extras
You can download it here.
ALAK
where can i find the extra files ?
ALAK
17341060069291232979114038293780.jpgthe old driver work its only the new driver  give me error
Earl_Intel
Hi ALAK,
For us to further investigate on the issue, kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Cold_Burn
I had this problem.
I used 7zip to open the EXE (install 7zip, right click on the Drive EXE, open with 7zip)
Find the "Extra" folder in the 7zip browser, extract it.
run the intel graphics software installer from the "extra" folder that you extracted.
If it says its installed I would just uninstall it with the graphics software installer exe and then run it again to install.
bobbycold_h
Hi all,
if problems persist please try removing the drivers using DDU. Follow this guide, re-install the newest applicable graphics driver and report back if the problem still occurs.
Robert W. (bobbycold_h)
Earl_Intel
Hi ALAK,
Earl E.
ALAK
i fix it on myself i should not disable event log service on windows if disable this service i cant install or run intel grapichs  software i dont know why
Earl_Intel
Hi ALAK,
Thank you for sharing this update with us.
To further isolate the issue, can you try to download the latest graphics driver version, you can download it on this link: Intel® Arc™ & Iris® Xe Graphics - Windows*
Let me know if the issue still persists on the latest drivers.
Earl E.
ALAK
its stil  same problem
Earl_Intel
Hi ALAK,
Thank you for your response.
No worries, I will further check on this, kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Earl E.
ALAK
Earl_Intel
Hi ALAK,
Thank you for providing the updated Intel SSU logs.
I'll check on this and provide an update on this thread as soon as I can.
Earl E.
Earl_Intel
Hi ALAK,
Thank you for patiently waiting.
Since I was unable to reproduce the problem, I have some clarifications regarding this issue:
  • Kindly clarify what Windows process is preventing you from installing the Intel Graphics Software?
  • May I know what driver version started this issue? or if this issue has been present since graphics driver version: 32.0.101.6325_101.6252 WHQL Certified?
  • Have you already tried clean installation option with the graphics driver installation?
  • Have you tried @bobbycold_h troubleshooting steps to uninstall the current graphics driver using DDU and installing the latest graphics driver afterwards?
Earl E.
ALAK
1- windwos event log
2-From the new software on first version
3- The driver install but  Intel Graphics Software not installed
Earl_Intel
Hello ALAK,
Noted on this, I will further check on this internally and provide you an update on this thread as soon as I can!
Earl E.
Earl_Intel
Hi ALAK,
I'm still currently investigating on the issue you brought up.
If it's not much of a hassle, can you provide the application and system logs of the system.
  1. Please provide an application event viewer log from your system. Below are the steps to generate the logs
    1. Right Click on the Start Button
    2. Click on Event Viewer
    3. Click on the chevron of the Windows Logs
    4. Right Click on the Application and select Save All Events As
    5. Save the file and send us a copy
    6. make sure to indicate the timestamp of the crash
  2. Please provide an System event viewer log from your system. Below are the steps to generate the logs
    4. Right Click on the System and select Save All Events As
I need to collect the logs to further investigate the crashes on both a system and application level.
Earl E.
Earl_Intel
Hi ALAK,
I wanted to check if you had the chance to review my previous post on how to get the system logs. In order to decide on the appropriate course of action to address this issue, kindly inform me as soon as possible.
Earl E.
Earl_Intel
Hi ALAK,
Earl E.
