Intel® Arc™ Discrete Graphics
4071 討論
terrible War thunder gaming experience
Donnerhall
初學者
2,708 檢視
Driver 32.0.101.6314 The game is WarThunder on Steam
In DX11, the game will suddenly drop frames for no reason. The software I am using shows that the GPU is only close to 700MHz, and the D3D occupancy rate is only 40% when drop happened,
In DX12  when you end a online game click Return the hanger it will randomly crash.
In Vulkan, FPS is a disaster, with only 60 FPS in the hangar. When the game starts, there is a probability that FPS will reach normal level(120-140) and also probability stabilize at 30fps. I don't know what I did to make it different
in general In any type API use ARC770 play WarThunder will have a  bad experience
FYI power is FSP HV pro 650w I think that's enough
0 積分
4 回應
RobbieR_Intel
主席
2,614 檢視
Hello Donnerhall,
Thank you for reaching out and for providing detailed information about the issue with War Thunder on the Arc A770 and the behavior across different APIs.
Kindly answer the following questions:
Is this behavior specific to War Thunder, or have you experienced similar issues with other titles?
Have you done other troubleshooting steps?
Is Resizable BAR enabled?
What is the game settings of War Thunder?
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
I look forward to your response!
Robbie R.
RobbieR_Intel
主席
2,571 檢視
Hello Donnerhall,
Robbie R.
ACarmona_Intel
2,539 檢視
Hello Donnerhall,
This is only a quick follow-up; we just wanted to check in with you, as we haven't received any feedback from you.
Carmona A.
ACarmona_Intel
2,539 檢視
Hello Donnerhall,
I hope you are doing well.
Since we have not heard back from you, we will now be closing our case.
If, in case you are just busy and still needed assistance, please submit a new question on our community: https://community.intel.com/, as this thread will no longer be monitored.
Thank you.
Carmona A.
回覆
