Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
AMT DTK Question
pieno
i need help using AMT DTK
when using the commander i have a problem with "take control "
in the redirection
i am trying to remotely set up windows from a local CD-drive
the problem here is the redirection option can't be activated before i add img file to the flobby drive and CD in the CD-drive
then i make reboot to remote CD drive and the windows installation begins
that makes a problem while intalling windows as theit installs it shows a message "if there's a disk in the flobby drive try to remove it "
and then it restarts begining the installation again
any help wz this ??
Sreelekshm_S_Intel
Which version of DTK are you using? Also, what is your AMT version?
Sree
pieno
AMT DTK ver. 0.48
AMT ver 2.0
tx in advance
pieno
sorry a little correction
the AMT ver is 2.1.0
Ylian_S_Intel
Hi. Oh yes, the way Intel AMT works, you must have both a CDROM and a Floppy image for IDE-R to work. You cannot do just one or the other. I am not sure how to fix your problem except that you should try using an empty floppy. There is no way the computer would be able to boot on an empty floppy disk.
If you have a real floppy disk drive on the console, you can then remove the floppy disk from the drive. Sadly, if you use a floppy image, there is no way to remove it.
Ylian (Intel AMT Blog)
