Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
AMT shared ip, no access
Kevin_M_
Hi all,
I have several  AMT box's and one is prooving to be a pain,  I have configured a shared dedicated ip address, and can access that ip address via wsman across the lan, all settings *appear* to be the same as other working box's however this one just wont give me access to the webgui, nor vnc even then it is configured.   I was wondering if anyone can give me some tips as to what to check ?
best regards
Kev
Gael_H_Intel
Could it have an Antivirus setting that is blocking management messages? (or the ports that AMT uses?)
Can you ping that system and can it ping your management console?
Have you tried doing a CMOS clear on it?  Sometime's that helps but you will have to reprovision if you do that.  What version of AMT is it? Is it a different version than the other systems?  All AMT Software/drivers/fw are up to date?
