Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
CPU TDP
Julio_Cesar_S_
Is there any api that provides the TDP (watts) processor?
I can't find.
Ty.
Gael_H_Intel
We answer questions regarding Intel Active Management Technology (vPro) on this forum.  I do not know what SDK a TDP api would be a part of.  (Sorry..)
Julio_Cesar_S_
ok sorry. =(
Bernard
Valued Contributor I
Maybe one of the MSR registers will be helpful.
Julio_Cesar_S_
procedure TForm2.GetKernelPerfStateInfo;
const
WbemUser ='';
WbemPassword ='';
WbemComputer ='localhost';
wbemFlagForwardOnly = $00000020;
var
FSWbemLocator : OLEVariant;
FWMIService : OLEVariant;
FWbemObjectSet: OLEVariant;
FWbemObject : OLEVariant;
oEnum : IEnumvariant;
iValue : LongWord;
begin;
FSWbemLocator := CreateOleObject('WbemScripting.SWbemLocator');
FWMIService := FSWbemLocator.ConnectServer(WbemComputer, 'root\WMI', WbemUser, WbemPassword);
FWbemObjectSet:= FWMIService.ExecQuery('SELECT * FROM KernelPerfState','WQL',wbemFlagForwardOnly);
oEnum := IUnknown(FWbemObjectSet._NewEnum) as IEnumVariant;
while oEnum.Next(1, FWbemObject, iValue) = 0 do
begin
Label5.Caption := (Format('Power %d',[Integer(FWbemObject.Power)]));// Uint32
FWbemObject:=Unassigned;
end;
end;
Don't show tdp. Tips?
Bernard
Can you access directly these MSR registers( on Ivy Bridge) 0x648 ,0x649, 0x64A?
constm
WMI.KernelPerfStates.Power does not exist. Don't crosspost this bullshit anymore. Just check.
WMI.KernelPerfStates.vbs :
Const wbemCimtypeDatetime  = 101    ' Date/time value
On Error Resume Next
Set d = CreateObject("WbemScripting.SWbemDateTime")
Set c = GetObject("winmgmts:\\.\root\WMI").InstancesOf("KernelPerfStates")
for each o in c
    WSH.Echo ""
    WSH.Echo "----"
for each p in o.Properties_
    if IsNull(p.Value) then
        WSH.Echo p.Name
    else
        if p.CIMType = wbemCimtypeDatetime then
            d.Value = p.Value
            WSH.Echo p.Name & " = " & d.GetVarDate()
        else
        if IsArray(p.Value) then
            WSH.Echo p.Name & " = " & Join(p.Value, ",")
        else
            WSH.Echo p.Name & " = " & p.Value
        end if
        end if
    end if
next
next
if Err <> 0 then
    WSH.Echo ""
    WSH.Echo "Error:", Hex(Err.Number), "-", Err.Description
    Err.Clear
end if
