Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Control AMT By Scripts
CLi37
Can I use AMT commands in a script language such as Tcl and Perl and execute the scripts? If AMT is like a DOS command line, I may need to install scripting language in the client, is it right?
Ajith_I_Intel
Hi Changl,
I am not sure if I understand your question correctly but AMT exposes two interfaces to communicate depending on the version of the firmware. You can communicate with AMT using SOAP API's or WS-Man (starting with AMT 3.0)API's. Please let us know if you have further questions.
Ylian_S_Intel
The SDK and the DTK both have some command line tools you could use to script simple tasks like waking up a computer, etc. The Intel AMT Terminal in the DTK also has a built-in scripting system so you can automate, for example, going into the BIOS of a computer remotly and changing settings.
Generally, you would run there management commands on a different computer, not on the computer you want to manage.
Ylian (Intel AMT Blog)
