Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1406 Discussions
Does the ISV Storage Lib(Linux) support the local access?
snaxum
Guys
From the SDK User Guide Section 3, I found it said the ISV Storage SDK(Linux) only supports the remote interface. Is it true?
I build the sample code ApiTest in FC7 and run it with root. The ISVS_RegisterApplication failed with the error code 4103. The command line is :
./apiTest -t http://localhost:16992/StorageService -user admin -pass Admin@123
Can anybody look into the issue for me?
Thanks a lot!
Gael_H_Intel
Hi - yes that is true, reason being is there is no HECI driver for linux (from within the SDK). However you can go out to OpenAMT.org and see if you can find what you need there.
