Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1429 Discussions
EventManagerService.SubscribeForGeneralAlert : Invalid parameter
gennadiy
AMT has version 5.0. I try to work with EventManagerServicefunction SubscribeForGeneralAlert.
I created and send string to AMT computer
1
192.168.1.22
and I got error "Failed to parse the request, Detail=Invalid parameter"
Where is my mistake?
Andrew_S_Intel2
Quoting - gennadiy
1
192.168.1.22
Do you have an event filter setup with an AlertSubscriptionPolicyID entry that matches the policyID you passed in?
gennadiy
Yes. I added pictute.
gennadiy
Quoting - gennadiy
On a picture it is visible that AlertSubscriptionPolicyID is equal policyID. It means not the reason of occurrence of an error. There can be a reason is in syntax Web service?
Gael_H_Intel
Quoting - gennadiy
Well, in looking at the SoapUI generated request it looks like you have everything that you need. One thing I notice is that in the Network Interface Guide, the IPv4Address appears to be a string and the example they give is in quotes. Maybe you need to add quotes to your Soap code?
I also notice that the name spaces in the Envelope are not the same ones you are using. Not sure if that is causing you problems either. You have also have a namespace in the body, where the wsdl file has all the name spaces in the Envelope line.
From the WSDL file:
http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://schemas.intel.com/platform/client/EventManager/2004/01" xmlns:ns1="http://schemas.intel.com/platform/client/Common/2006/01">
Your Code:
--The wholeWSDL file:
gennadiy
From the WSDL file:
Your Code:
Hi Gael,
Thank you. I found my mistake.
