Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
How to connect AMT in different wifi network?
bao_t_
Hi All,
I have one laptop which is enabled AMT vPro Core i7. I can connect this device to check System Status, Hardware Information... by using IE for example http://IPAddress:16992 in the same wifi network (SSID is myWifi ). But I cannot connect this device if the SSID is difference between two laptops.
How can I connect AMT in different wifi network?
Thanks for your help.
Joseph_O_Intel1
Hey Bao,
The Intel AMT firmware needs to have the wireless profile for both networks. So If the AMT Client is in Net A and the Management Console is in NetB they will not be able to connect. Unless of course there is a network infrastructure allowing NetA and NetB to communicate.
So either make the two wireless networks routable to each other or you will need both Wi-Fi profiles configured in the AMT Firmware. You can have a max of 16 profiles with 8 being user profiles (added via WebUI).
Joe
bao_t_
Thanks Joe very much.
I got it.
Bao
