Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
公告
IDE-R limitation
MPala11
新分销商 II
2,683 次查看
I redirect 4GB ISO file using IMRGUI.exe and then copied the iso file in AMT machine itself. Copy operation stopped around 2 GB. When I checked AMT SDK for IDE-R, I found a restriction The transferred file must be less than 2Gbytes.
Can anyone clarify the following?
1. The transferred file must be less than 2Gbytes Single file should not be greater than 2GB and can I copy the same file any number of times.
2. In DVD I have many files and total size is greater than 2GB, Can I redirect that complete DVD to AMT machine
3. If I try remote OS installation using an ISO file or DVD (size greater than 2GB and redirecting the ISO file or DVD), will that installation succeed
I couldnt understand the 2Gbytes restriction.
Mani
0 项奖励
1 解答
Gael_H_Intel
主持人
2,683 次查看
Hi Mani,
There is a 2GB restriction due to us supporting only CDs in the current version of AMT. (It's nice that we can also use DVDs, but we are currently limited by the "CD" size restrictions.)
For now you will need to use the smaller ISOs.
Gael
在原帖中查看解决方案
0 项奖励
3 回复数
Gael_H_Intel
主持人
2,684 次查看
Hi Mani,
Gael
0 项奖励
mauro_c_
初学者
2,683 次查看
Hi, is there still a limitation to transfer a .ISO file to AMT 6 and AMT 11 usind IDE-R, my .ISO file is about 4.8GB.
0 项奖励
Joseph_O_Intel1
2,683 次查看
Hey Mauro,
I can't find anything in the docs, nor within the redirection library that would dictate a size. However keep in mind the image gets downloaded to RAM, then launches. So if your using large files you may run into available memory issues.
Also when working with large iso's network speed is going to be an issue, so best practice is to initiate IDER boot, while the system is already in an OS. Reason is described here.
0 项奖励
回复
