Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Null or Invalid GUID
johanvandberg
I was wondering, is it possible to have the GUID null or invalid on an AMT system?
A collogue tells me it is possible on some systems when you pull out the power cord, take out the motherboard battery, and short the motherboard's battery pins to ensure all capacitors etc. are discharged.
Unfortunately we are not located in the same office or even have the same AMT systems in our test labs. I have tried this but my GUID stays whether that is from AMT or when it is read on the first boot after the procedure (via PXE).
Finally, if there is a way to get the GUID uninitialized, is it possible that the AMT system could register with the SCS using this invalid GUID?
Thank you for your inputs.
Sreelekshm_S_Intel
The GUIDs are initialized, stored and handled by Bios. So, it is possible that an AMT device gets null or invalid GUID but AMT will detect it as invalid and won't use it.
Sree
johanvandberg
Thank you Sree.
Thinking of a contingency plan:
1) Will the system recover or re-generate the GUID at some point? On my AMT systems (2.1 and 3.0) I do not see a method for me to provide a new GUID. But maybe you can guide me to some reading material to do it then.
2) By saying AMT will not use it, do you mean the system is now incapable of provisioning (it should be in factory state at this point)?
Johan.
Sreelekshm_S_Intel
No. It is a bios issue and we can't do anything here
It could be in the factory mode or in SMB mode if you put it in that way.
Sree
lakec
I have a simular problem...
I have about 20 computers reporting in my LANDesk Database with a AMT GUID of 00000000-0000-0000-0000-000000000001. Is there a way to reset this value?
Sreelekshm_S_Intel
GUIDs are generally set by the Bios. Do you have the latest version of Bios on your systems? If not, please try upgrading the Bios.
Sree
