Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Problem with webui
ivan_b_
Hi all.
Need your assist. I configured AMT via RCS server. When I deploying profile without ACL - I can successfully login to webUI(through default login "admin" and MEBx password).
But when in profile settings  I chose "access control list" option and added my domain account  - I got   an error when connecting to webui
This webpage is not available
The webpage at http://host.domain.com:16992/index.htm? might be temporarily down or it may have moved permanently to a new web address.
Error code: ERR_ACCESS_DENIED
Please help me to solve this problem
Gael_H_Intel
Hi - the WebUI's server is actually part of the Manageability engine - so it shouldn't be down.
Here is a blog that has some pointers on logging in via the ACL:  http://software.intel.com/en-us/blogs/2012/06/08/local-access-to-the-intel-amt-web-ui
Here are some things that we need to know:
  • What browser are you using?
  • What version of AMT?
  • Are you trying to use Active Directory Authentication?
ivan_b_
  • What browser are you using?      ---- I tried to login with several browsers, such as IE 10, Firefox, Chrome - result the same - "Error code: ERR_ACCESS_DENIED"
  • What version of AMT?  ------ 6.0.3
  • Are you trying to use Active Directory Authentication? ------- yes, I tried to login with my domain account credentials(I configured AMT profile on my RCS server with AD Integration).
Gael_H_Intel
Ok - since you are on AMT 6.0.1, make sure you are trying to connect from a remote system and that you can ping both ways.  Since you are using Active directory, you must use IE - did you take a look at this blog: http://software.intel.com/en-us/blogs/2012/06/08/local-access-to-the-int...
The blog provides instructions on how to set up IE to use Active Directory (most browsers attempt windows authentication as a default.)  If that still doesn't work you might want to check out this thread:  https://kc.mcafee.com/corporate/index?page=content&id=KB77546
It is possible that  the correct port number is not passed, preventing authentication (per Microsoft KB908209 -http://support.microsoft.com/kb/908209). Although the software fix for KB908209 has been applied to current versions of IE, you must also apply the associated registry key.
From the Implementation and Reference guide - here are the instructions on how to configure Intel AMT for Active Directory/Kerberos:  oftware.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments%2Fconfiguringintelamtforkerberosauthentication.htm  (I do not know if you configured your system this way..)
Gael
