Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Quiet system problem
phantasmania
Hi, I think that I'm on theworng forum. If so, please could you direct me to right one?
My problem is that since I assembled my PC and choosed to detect the second fan without havinga second fan on my PC the intel quiet system throws the following message on the power on:
Intel quiet system failed initialization and is non-operational
Re-check the intel quiet system configuration files settings
I searched the intel site for many hours on the this subjct and could not find specific documentation on how to debug it or to setup that files.
My mother board is DQ35MP and I've tried BIOS Upgrade o latest version and the message is still there. any ideas will be wellcome.
thankyou
Gael_H_Intel
Quoting - phantasmania
thankyou
Hi - we don't handle hand QST questions here on this forum (occasionally we can find the right information you may need to answer your questions, however. I have forwarded your question and we'll let you know once we get a response.
Gael_H_Intel
Hi phantasmania,
Do you have a DIMM in the first slot? The DQ35MP is an Executive Series board and thus is also equipped with AMT support. Are you planning to enable AMT (if you haven't already?)
If the cause foryour problem is that the ME is disabled (due to no memory being available), then you wouldn't be able to enable AMT either.
