Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
SCS 3.0 - "Certificate Cannot be issued"
adrianfreemantle
Hi all,
I have been using the SCS 3.0, and i have lately decided to start using TLS as well. The only problem is that I am having some trouble provisioning my clients. I get the following message in the Security Audit:
Cerificate cannot be issued - OS error code: 0x2. - Process interrupted.
I am trying to provision with Server Authentication. My "TLS Server Certificate Detils" have been configured and point to a valid standalone certificate server.
Any ideas?
Gael_H_Intel
Hi Adrian,
We will need to look further into your problem, but I was also wondering: Did you upgrade from SCS 1.2? And did you apply the patch? (The Patch is relevant when upgrading from 1.2 to 3.0 - we just uploaded the patch yesterday so you may not have seen it yet.)
Gael
adrianfreemantle
Sorry for taking so long to come back to you. The server installation was done from scratch and was not an upgrade from the old 1.2 SCS. To date I'm still unable to get this to work.
Gael_H_Intel
Hello Adrian,
We will need you to send us more information by enabling the full logging capability of the service. You can do this by going into the registry as follows:
Enter a string value V in the following:
HKEY_LOCAL_MACHINE->SOTWARE->Intel->AMTConfServer->LOG then LogLevel
This will create a more detailed log file called: scs_win_server.log We will also need the SCS log containing the described error.
Thanks!
adrianfreemantle
My server was rebooted over the weekend and has installed all the updates for 2003 Server. Now suddenly everything works ok. I have turned on the logging and will send you the log file should i experience this again. Thank you for the help.
Gael_H_Intel
Hi Adrian,
I am glad your problem solved itself!
Gael
adrianfreemantle
Hi Again.
I'm sad to say that this problem has returned once again. I have been provisioning my clients on Server Auth and today decided to try Mutual Auth.
I created a mutual auth profile, but had not yet provisioned any clients on my Mutual Auth profile. Shortly after creating the Mutual auth profile i provisioned one more client on my Server Auth profile and once again got the "Certificate Cannot be issued" error. Im not sure if the profile creation is significant or not, but both the profiles shared the same TLS Server Certificate Details.
I, restarted my SCS but the problem kept happening. I then restarted the entire server and the client provisioned propperly. I have attached the entire log below. This log is from after i restarted my SCS and just before i restarted the entire server.
So now i know the workaround, but do you know why this error is happening in the first place?
2007.07.19,12:44:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=.ManagersQueueManager.cpp,LINE=108,
to get request data: pop
2007.07.19,12:44:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3164,SOURCE=.WorkersProvisionerWorker.cpp,LINE=18,
Enter provisioner worker, user VMDALIOTadministrator
2007.07.19,12:44:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3164,SOURCE=.WorkersProvisionerWorker.cpp,LINE=523,
AMT Version: 2
2007.07.19,12:44:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3164,SOURCE=.WorkersProvisionerWorker.cpp,LINE=534,
AMT SetAdminAcl: 1
2007.07.19,12:44:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3164,SOURCE=.WorkersProvisionerWorker.cpp,LINE=543,
AMT Hello counts: 0
2007.07.19,12:44:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3164,SOURCE=.WorkersProvisionerWorker.cpp,LINE=554,
AMT ip: 192.168.0.11
2007.07.19,12:44:07,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3164,SOURCE=.WorkersProvisionerWorker.cpp,LINE=455,
Get core version, pid MN15-QCH9
2007.07.19,12:44:14,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3132,SOURCE=.hellolistenerHELLOThread.cpp,LINE=177,
Incoming connection from 192.168.0.11:16994, version 2, count 0, UUID DEBB91D02538DB118F15000EA68F75B9.
2007.07.19,12:44:14,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=3132,SOURCE=....CommongeneralDBUtils.cpp,LINE=376,
Exception when trying to push request - 0xCFFF0067 : Request is already in the queue..
2007.07.19,12:44:17,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,12:44:17,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3884,SOURCE=.WorkersRequestCertificateWorker.cpp,LINE=17,
Enter Get Certificates worker, user VMDALIOTadministrator
2007.07.19,12:44:17,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3884,SOURCE=.WorkersRequestCertificateWorker.cpp,LINE=27,
Retrieving certificates for Intel AMT device UUID: DEBB91D02538DB118F15000EA68F75B9.
2007.07.19,12:44:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3884,SOURCE=.CAInterfaceCAManager.cpp,L INE=570,
Enter process request 1
2007.07.19,12:44:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3884,SOURCE=.CAInterfaceCAManager.cpp,LINE=575,
Save Request
2007.07.19,12:44:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3884,SOURCE=.CAInterfaceCAManager.cpp,LINE=586,
Add new request
2007.07.19,12:44:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3884,SOURCE=.CAInterfaceCAManager.cpp,LINE=570,
Enter process request 3
2007.07.19,12:44:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3884,SOURCE=.CAInterfaceCAManager.cpp,LINE=610,
Delete Request
2007.07.19,12:44:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3884,SOURCE=.CAInterfaceCAManager.cpp,LINE=615,
Request to delete found
2007.07.19,12:44:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3884,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=223,
Add param @certificate value is binary
Add param @private_key value is binary
2007.07.19,12:44:19,E,SERVER=1,USER=VMDALIOTadministrator,THREAD=3884,SOURCE=.WorkersRequestCertificateWorker.cpp,LINE=222,
Certificate cannot be issued - OS error code: 0x2. - Process interrupted.
2007.07.19,12:44:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,12:44:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3064,SOURCE=.WorkersProvisionExceptionWorker.cpp,LINE=11,
Provisioning exception worker, user VMDALIOTadministrator
2007.07.19,12:44:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3580,SOURCE=.WorkersTaskDelayerWorker.cpp,LINE=11,
Delaying task, user VMDALIOTadministrator
2007.07.19,12:44:20,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3580,SOURCE=.WorkersTaskDelayerWorker.cpp,LINE=29,
Task 5 delayed
2007.07.19,12:47:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,12:47:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=220,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
Enter Maintenance worker, user VMDALIOTadministrator
2007.07.19,12:47:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=220,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
Maintenance worker pushes request for command_id=17 and uuid=
Maintenance worker pushes request for command_id=18 and uuid=
2007.07.19,12:47:07,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,12:47:07,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1380,SOURCE=.WorkersCleanLog.cpp,LINE=15,
Enter Clean log worker, user VMDALIOTadministrator
2007.07.19,12:47:07,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1560,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
Enter Clean status of requests worker, user VMDALIOTadministrator
2007.07.19,12:50:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,12:50:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=2820,SOURCE=.WorkersProvisionerWorker.cpp,LINE=18,
2007.07.19,12:50:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=2820,SOURCE=.WorkersProvisionerWorker.cpp,LINE=523,
AMT Version: 2
2007.07.19,12:50:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=2820,SOURCE=.WorkersProvisionerWorker.cpp,LINE=534,
AMT SetAdminAcl: 1
2007.07.19,12:50:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=2820,SOURCE=.WorkersProvisionerWorker.cpp,LINE=543,
AMT Hello counts: 0
2007.07.19,12:50:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=2820,SOURCE=.WorkersProvisionerWorker.cpp,LINE=554,
2007.07.19,12:50:07,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=2820,SOURCE=.WorkersProvisionerWorker.cpp,LINE=455,
2007.07.19,12:50:07,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,12:50:07,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3448,SOURCE=.WorkersRequestCertificateWorker.cpp,LINE=17,
2007.07.19,12:50:07,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3448,SOURCE=.WorkersRequestCertificateWorker.cpp,LINE=27,
2007.07.19,12:50:09,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3448,SOURCE=.CAInterfaceCAManager.cpp,LINE=570,
2007.07.19,12:50:09,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3448,SOURCE=.CAInterfaceCAManager.cpp,LINE=575,
Save Request
2007.07.19,12:50:09,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3448,SOURCE=.CAInterfaceCAManager.cpp,LINE=586,
Add new request
Enter process req uest 3
2007.07.19,12:50:09,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3448,SOURCE=.CAInterfaceCAManager.cpp,LINE=610,
Delete Request
2007.07.19,12:50:09,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3448,SOURCE=.CAInterfaceCAManager.cpp,LINE=615,
2007.07.19,12:50:09,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3448,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=223,
2007.07.19,12:50:09,E,SERVER=1,USER=VMDALIOTadministrator,THREAD=3448,SOURCE=.WorkersRequestCertificateWorker.cpp,LINE=222,
2007.07.19,12:50:10,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,12:50:10,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=544,SOURCE=.WorkersProvisionExceptionWorker.cpp,LINE=11,
2007.07.19,12:50:10,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=772,SOURCE=.WorkersTaskDelayerWorker.cpp,LINE=11,
2007.07.19,12:50:10,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=772,SOURCE=.WorkersTaskDelayerWorker.cpp,LINE=29,
Task 5 delayed
2007.07.19,12:52:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,12:52:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=2436,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
2007.07.19,12:52:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=2436,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.07.19,12:52:07,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,12:52:07,INFORMATI ONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=2564,SOURCE=.WorkersCleanLog.cpp,LINE=15,
2007.07.19,12:52:07,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3776,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
2007.07.19,12:53:09,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
ADODB Error: Source : Microsoft OLE DB Provider for ODBC Drivers Description : [Microsoft][ODBC SQL Server Driver][SQL Server]Login failed for user 'AMTSCS_VMARYEHDC.VMDALIOT_T+o6c9&Q'.
2007.07.19,12:53:09,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerConnectionHelper.cpp,LINE=42,
The connection with the server database has been lost.
2007.07.19,12:53:10,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:10,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:11,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:11,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:12,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
ADODB Error: Source : Microsoft OLE DB Provider for ODBC Drivers Description : [Microsoft][ODBC SQL Server Driver][DBMSLPCN]General network error. Check your network documentation.
2007.07.19,12:53:12,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:13,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:13,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:14,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:14,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:15,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:15,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:16,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:16,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:17,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:17,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:18,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:18,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:19,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:19,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:20,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:20,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:21,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:21,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:22,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:22,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:23,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:23,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
ADODB Error: Source : Microsoft OLE DB Provider for ODBC Drivers Description : [Mic rosoft][ODBC SQL Server Driver][SQL Server]Login failed for user 'AMTSCS_VMARYEHDC.VMDALIOT_T+o6c9&Q'.
2007.07.19,12:53:24,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:24,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:25,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:25,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:26,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:26,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:27,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:27,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:28,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:28,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
ADODB Error: Source : Microsoft OLE DB Provider for ODBC Drivers Description : [Microsoft][ODBC SQL Server Driver][SQL Server]Lo gin failed for user 'AMTSCS_VMARYEHDC.VMDALIOT_T+o6c9&Q'.
2007.07.19,12:53:29,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=948,SOURCE=.mainMainServer.cpp,LINE=398,
Stopping server... (0)
2007.07.19,12:53:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3664,SOURCE=.mainConfigurationServer.cpp,LINE=202,
Stopping all managers ...
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=3632,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=1600,SOURCE=.ManagersQueueManager.cpp,LINE=134,
Exception when processing HELLOTread - -805371009 : The connection with the server database has been lost.
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=3632,SOURCE=....CommongeneralLogger.cpp,LINE=333,
Unexpected exception when processing cspi_log
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=3664,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=3664,SOURCE=....CommongeneralLogger.cpp,LINE=333,
2007.07.19,12:53:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3664,SOURCE=.ManagersHELLOListener.cpp,LINE=26,
Finishing HELLO listener in port 9971.
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=440,SOURCE=.ManagersPollerManager.cpp,LINE=71,
Exception when processing Poller checker - 0xCFFF037F : The connection with the server database has been lost..
2007.07.19,12:53:3 0,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=2088,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=2088,SOURCE=....CommongeneralLogger.cpp,LINE=333,
2007.07.19,12:53:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=2088,SOURCE=.ManagersHELLOListener.cpp,LINE=99,
HELLO Listener has been stopped.
2007.07.19,12:53:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3664,SOURCE=....CommongeneralSCSThread.cpp,LINE=104,
HELLO listener stopped
Poller manager stopped
Queue manager stopped
Delayed manager stopped
Maintenance manager stopped
2007.07.19,12:53:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=3664,SOURCE=.mainConfigurationServer.cpp,LINE=213,
Server stopped.
2007.07.19,12:53:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=248,SOURCE=....CommongeneralSCSThread.cpp,LINE=104,
Configuration Server stopped
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=248,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=248,SOURCE=....CommongeneralLogger.cpp,LINE=333,
2007.07.19,12:53:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=248,SOURCE=.mainMainServer.cpp,LINE=412,
Server stopped.
2007.07.19,12:53:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTadministrator,THREAD=248,SOURCE=.mainMainServer.cpp,LINE=414,
Finishing stopping the server
2007.07.19,12:53:30,ERROR,SERVER=1,USER=VMDALIOTadministrator,THREAD=948,SOURCE=.mainMainServer.cpp,LINE=236,
&nb sp;StartServiceCtrlDispatcher returned
2007.07.19,13:00:29,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1560,SOURCE=....CommongeneralLogger.cpp,LINE=50,
Found matching messages file (3.0.2.9)
2007.07.19,13:00:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1560,SOURCE=.mainMainServer.cpp,LINE=216,
Starting server
2007.07.19,13:00:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1560,SOURCE=.mainMainServer.cpp,LINE=191,
AMTConfig Service properly installed , continue with start-up
2007.07.19,13:00:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1560,SOURCE=.mainMainServer.cpp,LINE=231,
AMTConfig Service Entered service code
2007.07.19,13:00:30,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=.mainConfigurationServer.cpp,LINE=127,
Checking the user VMDALIOTAdministrator
2007.07.19,13:00:50,ERROR,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
ADODB Error: Source : Microsoft OLE DB Provider for ODBC Drivers Description : [Microsoft][ODBC SQL Server Driver][DBMSLPCN]SQL Server does not exist or access denied.
2007.07.19,13:00:50,ERROR,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=....CommonConnectionManagerConnectionHelper.cpp,LINE=42,
2007.07.19,13:00:58,ERROR,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=118,
ADODB Error: Source : Microsoft OLE DB Provider for ODBC Drivers Description : [Microsoft][ODBC SQL Server Driver][SQL Server]Cannot open database "IntelAMT" requested by the login. The login failed.
2007.07.19,13:01:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=.mainConfigurationServer.cpp,LINE=24,
Checking user....
2007.07.19,13:01:06,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=.mainConfigurationServer.cpp,LINE=27,
Connecting to the database
2007.07.19,13:01:10,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=.mainConfigurationServer.cpp,LINE=141,
Registering the server
2007.07.19,13:01:10,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=....CommongeneralEnvironment.cpp,LINE=777,
Registering server...
2007.07.19,13:01:11,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=.mainConfigurationServer.cpp,LINE=154,
Starting QUEUE Manager thread
2007.07.19,13:01:11,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=.mainConfigurationServer.cpp,LINE=158,
Starting DELAYED Manager thread
2007.07.19,13:01:11,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=.mainConfigurationServer.cpp,LINE=162,
Starting POLLER Manager thread
2007.07.19,13:01:11,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=.mainConfigurationServer.cpp,LINE=168,
Starting Maintenance Manager thread
2007.07.19,13:01:11,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=.mainConfigurationServer.cpp,LINE=177,
Starting HE LLO Listener thread
2007.07.19,13:01:11,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=.ManagersHELLOListener.cpp,LINE=20,
Start HELLO listener as user VMDALIOTAdministrator, in port 9971.
2007.07.19,13:01:11,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=1624,SOURCE=.mainConfigurationServer.cpp,LINE=181,
Server started with user VMDALIOTAdministrator.
2007.07.19,13:01:11,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3260,SOURCE=.ManagersHELLOListener.cpp,LINE=75,
Listening on port 9971 for incoming connections.
2007.07.19,13:01:13,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3236,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,13:01:13,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3300,SOURCE=.WorkersProvisionerWorker.cpp,LINE=18,
Enter provisioner worker, user VMDALIOTAdministrator
2007.07.19,13:01:13,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3304,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=16,
Enter Maintenance worker, user VMDALIOTAdministrator
2007.07.19,13:01:13,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3300,SOURCE=.WorkersProvisionerWorker.cpp,LINE=523,
AMT Version: 2
2007.07.19,13:01:13,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3300,SOURCE=.WorkersProvisionerWorker.cpp,LINE=534,
AMT SetAdminAcl: 1
2007.07.19,13:01:13,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3300,SOURCE=.WorkersProvisionerWorker.cpp,LINE=543,
AMT Hello counts: 0
2007.07.19,13:01:13,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3300,SOURCE=.WorkersProvisionerWorker.cpp,LINE=554,
2007.07.19,13:01:13,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3304,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.07.19,13:01:14,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3304,SOURCE=.WorkersMaintenanceWorker.cpp,LINE=112,
2007.07.19,13:01:14,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3300,SOURCE=.WorkersProvisionerWorker.cpp,LINE=455,
2007.07.19,13:01:14,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3236,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,13:01:14,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3344,SOURCE=.WorkersCleanLog.cpp,LINE=15,
Enter Clean log worker, user VMDALIOTAdministrator
2007.07.19,13: 01:14,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3236,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,13:01:14,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3356,SOURCE=.WorkersCleanRequestsStatus.cpp,LINE=15,
Enter Clean status of requests worker, user VMDALIOTAdministrator
2007.07.19,13:01:15,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3236,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,13:01:15,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=.WorkersRequestCertificateWorker.cpp,LINE=17,
Enter Get Certificates worker, user VMDALIOTAdministrator
2007.07.19,13:01:16,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=.WorkersRequestCertificateWorker.cpp,LINE=27,
2007.07.19,13:01:18,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=.CAInterfaceCAManager.cpp,LINE=570,
2007.07.19,13:01:18,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=.CAInterfaceCAManager.cpp,LINE=575,
Save Request
2007.07.19,13:01:18,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=.CAInterfaceCAManager.cpp,LINE=586,
Add new request
2007.07.19,13:01:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=.CAInterfaceCAManager.cpp,LINE=570,
Enter process request 2
2007.07.19,13:01:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=.CAInterfaceCAManager.cpp,LINE=594,
Get Request
2007.07.19,13:01:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=.CAInterfaceCAManager.cpp,LINE=598,
Request found
Get Request
Request found
Get Request
Request found
Get Request
2007.07.19,13:01:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=.CAInterfaceCAManager.cpp,LI NE=598,
Request found
2007.07.19,13:01:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=223,
2007.07.19,13:01:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=.WorkersRequestCertificateWorker.cpp,LINE=150,
The requested certificate was issued
2007.07.19,13:01:19,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3392,SOURCE=.WorkersRequestCertificateWorker.cpp,LINE=196,
Get certificates terminated OK
2007.07.19,13:01:20,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3236,SOURCE=.ManagersQueueManager.cpp,LINE=108,
2007.07.19,13:01:20,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=57,
Finishing provisioning amt DEBB91D02538DB118F15000EA68F75B9, Username VMDALIOTAdministrator
2007.07.19,13:01:20,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=66,
Start configuring the Intel AMT device UUID: DEBB91D02538DB118F15000EA68F75B9.
2007.07.19,13:01:21,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersUpdateRNGKeyWorker.cpp,LINE=60,
Set rng key on Intel AMT device.
2007.07.19,13:01:21,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersClockSyncWorker.cpp,LINE=61,
Synchronize clock on Intel AMT device.
2007.07.19,13:01:21,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=384,
Set domain name to vmdaliot.com.
2007.07.19,13:01:21,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=388,
Set the host name to amt1.
2007.07.19,13:01:21,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=394,
Set VLan Parameters.
2007.07.19,13:01:21,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=405,
Set Ping Response.
2007.07.19,13:01:22,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=479,
Adding TLS client certificate.
2007.07.19,13:01:22,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=1022,
Set TLS options.
2007.07.19,13:01:22,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=1083,
Set enabled interfaces.
2007.07.19,13:01:22,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersPowerPoliciesWorker.cpp,LINE=84,
Set power policies.
2007.07.19,13:01:22,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=1142,
Generate a new PID for Intel AMT device UUID: 755Q-PJ3F.
2007.07.19,13:01:23,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=1172,
Change admin password
2007.07.19,13:01:23,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=1183,
Change admin password.
2007.07.19,13:01:23,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=313,
Commit changes.
2007.07.19,13:01:23,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=....CommongeneralAMTUtilities.cpp,LINE=230,
Entering commit changes
2007.07.19,13:01:24,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=....CommongeneralAMTUtilities.cpp,LINE=243,
Leaving ok commit changes
2007.07.19,13:01:25,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=.WorkersProvisionerFinalWorker.cpp,LINE=346,
Exit normally processing provisioning worker.
2007.07.19,13:01:25,INFORMATIONAL,SERVER=1,USER=VMDALIOTAdministrator,THREAD=3528,SOURCE=....CommonConnectionManagerADODB.cpp,LINE=223,
Gael_H_Intel
Hi Adrian,
Thanks for the update. I have forwarded your log info to our SCS Support Engineers. I'll update this issue as soon as we get a response from them.
