Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
SCS with AD
vprosh
Hi, Everybody
I got a problem during setup integration SCS with AD. and i take look "Installation and Manual", about AD description as follow this below.
"Integration with Active Directory
Intel SCS integrates the Intel AMT device with Microsoft Active Directory by creating a directory entry based on the Intel-Management-Engine class. The SCS installation includes scripts used by the administrator to:
Extend the Active Directory schema to support the Intel-Management-Engine class
Populate the Intel-Management-Engine attributes
During setup, Intel SCS:
Creates an Active Directory object representing the Intel AMT device
Creates an attribute for connecting the AD computer object to the AMT object."
I can't understand this paragraph , can anybody explain for this?
I attmept deploy SCS with AD environment, and how to configuation AD?
Great thanks
Sreelekshm_S_Intel
Could you please provide more specifics on your problem, like what errors you are getting while integrating SCS and AD? You could send us the log info and we will look into it.
Have you downloaded the latest SCS 3.1? This has got some errors fixed in the scripts. If you are not using the latest scripts, please do so. You can download this from http://software.intel.com/en-us/articles/download-the-latest-version-of-intel-amt-setup-and-configuration-service-scs
Sree
Sreelekshm_S_Intel
I you haven't turned on logging, you can do this by going into the registry as follows: Enter a string value V in the following: HKEY_LOCAL_MACHINE->SOTWARE->Intel->AMTConfServer->LOG then LogLevel
Sree
vprosh
Yes, I have got latest SCS 3.1. and attempts connection SCS server by console, program prompte "Logon fail". I used https connect. Does this error with my network environment?
CA_Server ------------SCS_Server------------AMT client
                      SCS_Console
Sreelekshm_S_Intel
Your network setup looks fine. Are you having any trouble connecting to SCS server from the console?
Sree
