Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1407 Discussions
[SOL] unable to see the text when I reset the computer
vickyamt2007
I try to reset a computer remotely and also want to see the dos text through SOL. However, there is no dos text sending to the console, but the reset function works okay. I could work this function correctly in other machines; however, in the motherboard (Matanzas FAB-3), I cannot succeed on seeing dos text through SOL, but I can see the sol running successfully when I try to do PowerReset + RunToBiosPage + SOL.
I also try the DTK tool, which can successfully runs the both cases I mentioned above.
I really appreciate your any suggestion.
Maria_Camila_Gomez-S
Vicky, the same happened to me because I had a very old version of the AMT firmware.
After updating I did not have anymore trouble with the SOL issue.
May be a different case but anyway new firmware has lots of improvements.
Maria
Gael_H_Intel
Amen! smiley [:-)]
Yes - please check to make sure you have the latest firmware on your system - upgrading is very often the quickest way to happiness.
