Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1409 Discussions
Unable to control remote machine via serial over LAN
sandeep_manchala
Am using HP VproDC7700 machines , in one machine i installed Management development toolkit & running as provision server and other as client (HP DC7700) , am able to control all remote commands like remote reboot via BIOS , rempte power off , down etc., for client from provisioning server
but when am opeining serial over LAN display is showing at boot timeand after that itsnt displaying nothing on terminal
Andrew_S_Intel2
Could you describe how you provisioned the system in a little bit more detail? It sounds like you're provisioning in Enterprise mode instead of SMB mode, and if that's the case there is the possibility that SOL and IDE-R are disabled.
Are you using the DTK (managability Development toolkit)to run the remote commands you mentioned? From the Remote Control tab when you click the Take Control button I mean. If that is how you're running the commands, do all of the options under Remote Control show up as enabled?
