Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
ZTCLocalAgent - activate not sending hello packets
MPala11
New Contributor II
Hi All,
I'm trying remote configuration using Windows\\Intel_Manageability_Configuration\\Bin\\ConfigurationServer.exe and Windows\\Intel_Manageability_Configuration\\Bin\\ZTCLocalAgent.exe
available in AMT SDK. Run the configurationserver in windows xp system(non-AMT system) which listens on port 9971(ip 192.168.0.132) and
execute the ZTCLocalAgent.exe from AMT 7.0 system(ip 192.168.0.205), command used as below
ZTCLocalAgent.exe -activate -dns machine-name.in.test.com
Hostname:machine-name
Domainname:in.test.com
Output of above command(copied last four lines of command output)
Provisioning TLS Mode:
PKI
Activate Intel AMT configuration:
Success
Configuration server is not receiving any hello packets from ZTCLocalAgent.exe, what coulf be the problem
Tried checking port 9971 of configuration server from AMT client using telnet and able to access 9971, both machines are in same domain
what will be the value for -dns option in ZTCLocalAgent- fqdn of configuration server or domain name alone
Will ZTCLocalAgent send hello packet to "provisionserver" hostname alone or any hostname like (machine-Name)
Mani
Jerome_E_Intel
Hi Mani.
1) Make sure you have a DHCP and DNS server set up in your environment and that they are properly configured for your domain (in.test.com). Note: if everything is good, you can omit the -dns parameter for ztclocalagent)
2) Ensure you have a DNS entry for provisionserver that resolves to the system that is running configurationserver (192.168.0.132 in your above example)
Configurationserver should then see hello packets.
MPala11
New Contributor II
Thanks for your reply
Is it possible to give FQDN for -dns option without having alias name as provisionserver in DNS?
I'm trying to send hello packet directly to machine-name(hostname-192.168.0.132) without having entry in DNS for provisionserver.
Can you explain what vaue we need to give for -dns option- FQDN or domain name?
Mani
RBens2
Valued Contributor I
Hi Mani,
The name of "Provisionserver" is built into the FW. If you don't want to use a DNS entry for the servername, then you will need to go into the MEBx of each system and change the name of the SCS or you will need to use a USB key to provision each system with the different name. It's probably easier to setup an alias in your DNS for the provisioning server, that way you don't need to physically touch each system.
Roger
