Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
issue with dc7700p BIOS / firmware upgrade
vramanx
i tried to upgrade one of our dc7700p machines to the latest HP BIOS / ME firmware --
VERSION: 3.03 Rev. A
the BIOS upgrade succeeded using hpqflash.exe
but the ME firmware upgrade is failing with the below error message.
C:swsetupSP36847ME FlashLocal-Win>FWUpdLcl.exe 221_1034.BIN -generic
Error: Failed to receive last update status from the firmware
any help is appreciated.
Sreelekshm_S_Intel
This seems to be an OEM specific error. So you might have to contact HP for this. BTW, which version of AMT is this?
Sree
vramanx
i finally made a DOS floppy, booted, and ran the DOS version of the tool. it started flashing. unfortunately, due to KVM mixup, i hit ctrl+alt+del in DOS thinking that it is my xp box. i tried it again and it said that an update is already in progress. how do i get out of this situation?
Ajith_I_Intel
Did you get the utility from HP? This issue sounds like something you need to work with your OEM. Too bad that the firmware upgrade process was interrupted. Meanwhile, I will check with my internal resources if there is anything you can do get out of this situation and get back to you.
am
removed
Ajith_I_Intel
Hi Anwar,
You need to work with your OEM, HP in your case, regarding this issue.
john_prothro
Please try this resource and let us know if someone is or is not able to help you.
HP does have a forum for customers to take issues to regarding their HP desktops/notebooks, etc... it is not a AMT specific site, however, they will take all questions HP.
http://forums1.itrc.hp.com/service/forums/bizsupport/home.do?forumId=2
