Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1407 Discussions
manageability commander tool has stopped working.. in windows 7
nor500
Intel Manageability Developer Tool Kit is not running under windows 7andwindows 2008 r2 rc. I had already tried compatiblity mode, it didn't help. The error message I got after I try run it: manageability commander tool has stopped working.. What can I do?
jacace
Quoting - nor500
AMT does not depend on underliying OS, so maybe this issue is something about execution permissions, have you try running as administrator?
I hope this helps.
Javier Andrs Cceres Alvis
Blog Personal: http://speechflow.spaces.live.com/
Blog Intel: http://software.intel.com/en-us/blogs/author/javierandrescaceres/
Andrew_S_Intel2
I hope this helps.
Nor500,
The current version of the DTK isn't yet supported on Windows 7. Did you see the previous thread on rebuilding the source that's provided to get the DTK running on Windows 7? Brett was fairly detailedon how you would do so, and the source is provided for the DTK so it would be fairly straightforward.
http://software.intel.com/en-us/forums/showthread.php?t=67252
nor500
Can you tell me, when is manageability commander tool going to support windows 7 64 bit?
Lance_A_Intel
Quoting - nor500
Unfortunately the release plan for commander is not available.
I know that team is working on improvments to it but do not know when the next release will be and do not know if it will have Win 7 64-bit support.
As Andy mentioned above you can use the source to compile yourself.
