Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
vPro for Data recovery software
indusgeek
Let say i want to enable Vpro technology for Data recovery software. Assume one situation client system is crashed & it is located at remotelocation. Now tell us how we can Recover Data using Quick Recovery if that system is VPro enabled.
Pls guide us how we can best advantage your technology.
Cheers!
Lance_A_Intel
When the client system is crashed, you would first want to repair it. You can use IDE-redirection to boot from a remote good image, with serial-over-LAN to interact with the client in a console window. With this setup you can remotely diagnose the system problem. If it is a software issue, you can remotely repair it now that you are connected. If it is a hardware problem you will need someone to go to the system to fix it.
Now that the system is fixed, the data recovery software can be run on the client's host OS.
