Hi all
I used tachyon_studio sample that have in Intel folder (C:\Program Files (x86)\Intel\Parallel Studio 2011\Samples\en_US) and compare file size that built by Intel C++ Compiler and Visual C++ Complier.
File size of tachyon.common project that built by Intel C++Compiler: 21,728,118 bytes
File size of tachyon.common project that built by Visual C++ Complier: 3,046,742 bytes
Although program is still working correctly, but the size(built by Intel C++Compiler) is increased too much. Can anyone give me some explanations? Is this normal or abnormal?
I'm using Intel Parallel 2011 Update 1 and Visual Studio 2008.
- « Previous
- 1
- 2
- Next »
Hi Tuan,
Could you please let me know what format is the files that you have attached? Because it seems like its an executable? Please do let me know. Sorry for the delay.
Sukruth H V
Hi Sukruth H V
The attached files contain the VC++ project file.
It is not an executable file.
Please use 7zip software, change tachyon_studio.001.7z to tachyon_studio.7z.001 and similar with other files before unzip.
Hanh
Hi Sukruth H V,
Please change 000 to 001.
I can't send a complete project because I can't upload file size more than 200KB from company.
I'm sorry about inconvenience.
Hanh
Hi Hanh,
I have tried that and seems its not working on my side. I continued to get the same error that i had posted you before. Since you say that the upload capacity is just 200KB, I guess i have no option to suggest the way to upload these testcases.
Sukruth H V
Hi Hanh,
Thanks for your efforts in sending me the testcase. I had checked with 13.1 compiler and found that with IPO option the object files are created and much heavier (~25 MB) when compared to NON-IPO version which is (~2MB).
So with IPO there are 2 phases that are involved :-
Phase 1 :- Compile you application using /Qipo option, which would basically generate the MOCK object files which contains the Intermediate represenatation and also heavier.
Phase 2 :- Now link your application with /Qipo option and now you should see an Optimized executable. Infact i see in your case that the *.obj files generated with /Qipo is bloated (increased) in your testcase also. So this is what desired/expected.
I would like to send source code that file size in case enable /Qipo is lower than file size in case disable /Qipo.
But you conveyed that /Qipo created obj's are smaller that the non-ipo one's right? I am not able to see that behaviour with your testcase.
I am building the "tachyon.common" project with Intel C/C++ compiler. Please do let me know if i am doing something wrong.
Sukruth H V
Hi Sukruth H V,
I don't mean about object files, I mean about dll file.
In this case:
Build tachyon.common with option /Qipo, the size of tachyon.common.dll is about 167 KB.
Build tachyon.common without option /Qipo, the size of tachyon.common.dll is about 222 KB.
Hanh
- « Previous
- 1
- 2
- Next »
