Intel® C++ Compiler
7956 Discussions
Disabling Profiling for set of functions in a file
hhegde
When migrating from Intel Compiler version 9 to 10, we found that certain functions in a file were being profiled, which were not being done earlier.
- Is there a command-line option in icc(v10) which would disable profiling for a set of functions?
I see an option in profmerge that can do the same
-exclude_funcs ='blah,.foo,bar'
Om_S_Intel
Quoting - hhegde
The profmerge is called by intel compiler driver internally in feedback compilation (/Qprof_use). You can merge the profile information using profmerge tool and pass on the .dpi file with /Qprof_use option.
hhegde
In a build environment, the profile information(dpi file) is part of source control and if we want to check the effect of profiling on a function, the command line option for disabling would be a better choice.
In a function having memcpy, calling intel_vec_memcpy or intel_fast_memcpy would be dependent on profiling and the corresponding performance variation.
Hrishi
Om_S_Intel
Quoting - hhegde
You may try /Qoption,prof,"exclude_function=blah,foo,bar" to pass the option to profmerge. Though I have not tried it myself. Please post your finding as it will inforative and will help others.
