Intel® C++ Compiler
7956 Discussions
ICC 10.1 inline assembler weirdness
levicki
Valued Contributor I
I noticed that latest ICC 10.1 generates long conditional jumps where short ones would suffice even if you write jz short label (I am talking about inline assembler code). For example it spits out 0F 84 20 00 00 00 instead of 74 24 which clearly doesn't make any sense. Any ideas?
levicki
Can someone from Intel please tell me if what I am seeing here is intended behavior or not? Has anyone else seen this?
levicki
Nice to see that there is no one around to help me a bit when I need it.
That fact combined with the latest bugs introduced into the forum software by incapable administrators (no edit button, editing kills attachment,
 font not fixed width) really kills my motivation to hang around here and help other people.
JenniferJ
Hi Igor,
We've tried several cases trying to duplicate the problem, but no success. Could you send yourtestcase? andwhat the compile options used. If you like, you can send to Premier Support
JenniferJ
Hi Igor,
We've tried several cases trying to duplicate the problem, but no success. Could you send yourtestcase? andwhat the compile options used. If you like, you can send to Premier Support for
JenniferJ
Hi Igor,
We've tried several cases trying to duplicate the problem, but no success. Could you send yourtestcase? andwhat the compile options used. If you like, you can send to Premier Support for secority r
JenniferJ
Hi Igor,
We've tried several cases trying to duplicate the problem, but no success. Could you send yourtestcase? andwhat the compile options used. If you like, you can send to Premier Support for security reason.
levicki
Here you go, number of NOPs between jumps corresponds with actual instruction sequence lengths in our code. Should work with any compiler options, I have tested using ICC 10.1.021 IA32 for Windows. Use /c /FAc to get the .cod file and check those JE encodings. I have submitted it to the Premier support (#481387).
