- « Previous
- 1
- 2
- Next »
There are reference of use of min/max reductions in gcc 4.7 and up. See :
http://www.techdarting.com/2013/06/openmp-min-max-reduction-code.html
As in OpenMP 3.1 specification ( http://openmp.org/wp/2011/07/openmp-31-specification-released/ )
But I do not use gcc, I only found the references in several sites some time ago.
Great to have support for min/max reduction as defined by OpenMP 3.1 and 4.0 !
Thanks !
icc and ifort 15.0.0 required stuff like
#if __INTEL_COMPILER >= 1500
#pragma omp simd reduction(min: x)
to optimize a min reduction .
The icpc alternative of using std::min in place of if or ? is good but doesn't optimize with gcc (nor MSVC).
The options are expanded in 15.0.3 to where
x= a[1];
#if defined _OPENMP && _OPENMP >= 201307
#endif
for(int i= 2; i<=n; ++i)
if(a < x) x= a;
optimizes ( with or without omp simd reduction). Apparently, the _OPENMP macro has been updated to recognize the date of the OpenMP 4.0 standard. The last documentation I saw said that Intel didn't plan a full OpenMP 4 implementation (at least not in 15.x updates) and thus the OpenMP 4 standard date would not be recognized (but OpenMP 4 is listed as a goal of 16.0 beta).
I don't know which 15.0 update introduced the new flexibility; it works the same in the 16.0 beta.
icc (and ifort) have corrected the hassles in getting optimized min|max reduction.
I stumbled on this when noticing that 16.0 beta introduced some max|min optimizations to Cilk(tm) Plus CEAN notation.
If I set -fp-model source and remove #pragma, opt-report says vectorization is disabled accordingly, but it doesn't hurt performance as much as might be expected. I don't see why this should disable vectorization, unless there is some odd problem with values differing by less than FLT_EPSILON not showing inequality in simd compare. gcc doesn't optimize well without -ffast-math, and omp simd reduction helps only a little.
I was confused when digging up this old thread, as it didn't say which language forum it was attached to.
- « Previous
- 1
- 2
- Next »
