Intel® C++ Compiler
_intel_new_feature_proc_init
li_x_2
c:\>icl demo.cpp
LNK2019: error cannot resolve the external symbol ___intel_new_feature_proc_init,
Why?
Only "icl /Od demo.cpp" is OK,that is option /O1 and /O2 and /O3 are compiled incorrectly; What happend to it?Why all options of cl compiler are correct?
My computer's intel processor:
The third generation of Intel core i5-3210M processor core @ 2.50GHz
Step E1
Speed 2.50 GHz (100 x MHz 25)
Number of processors core number: 2 / thread number: 4
Core code Bridge Ivy
Production process 22 nm
H2 Socket (LGA 1155).
First level data cache 2 KB 32 8-Way, byte, 64 lines X
Level 1 code cache 2 KB 32 x, 8-Way, 64 lines byte
Two level cache 2 x 256 KB, 8-Way, 64 lines byte
Three level cache 3 12-Way, MB, 64 lines byte
SSE, SSE2,, SSE3, SSSE3, SSE4.1, SSE4.2, HTT,, EM64T, EIST, Boost, MMX, Turbo
JenniferJ
Looks like the build window isn't setup correctly.
Please open the build window from "start" menu: all programs > Intel Parallel Studio xxx > Compiler and Performance Libraries...> IA32 Visual Studio xxx Mode
Then build the app from this window.
Jennifer
TimP
You may not have the library paths set up to match your icl. Best keep Visual studio and intel compiler paths out of your basic windows settings and use the cmd start menu shortcut set up during installation. If you wish to change the installation path of icl, remove it and install with the new path.
li_x_2
I use vs2010 to compile it,but the error list say "Cannot open impi.lib".I searched all paths of computer,I didn't find it.The "impi.lib" really exists?
JenniferJ
Jennifer
li_x_2
Thank you for solving that problem,but why can only "IA32 Visual Studio xxx Mode"  be used to make it ?I set up "path" variable in environment  of Windows OS ,but I didn't compile it directly using "icl  somefile.cpp" by CMD window.All  in all ,thank you.
