Intel® C++ Compiler
xilink error under vsNET2002
beaupaisley
When using icl 9.0 from the vs.NET 2002 environment we get the error.
xilink: error: problem during multi-file optimization compilation (code 1)
This did not occur when running within the vc6 ide. Please advise.
(This is compiled with /Od so there should be no optimizations)
Thanks, Beau Paisley
TimP
This message is usually misleading. Without a quotation of the errors which led up to it, nothing can be said.
beaupaisley
Tim, Thank you for the rapid response. I rebuilt with linking as /VERBOSE but it does not to give much more details. The output follows. Also, I have attached the BuildLog file. Thanks, beau
------ Build started: Project: table, Configuration: Debug Win32 ------
table - up-to-date.
Build log was saved at "file://C:OM ableDebugBuildLog.htm"
table - 0 error(s), 0 warning(s)
------ Build started: Project: com, Configuration: Debug Win32 ------
com - up-to-date.
Build log was saved at "file://C:OMcomDebugBuildLog.htm"
com - 0 error(s), 0 warning(s)
------ Build started: Project: dde, Configuration: Debug Win32 ------
dde - up-to-date.
Build log was saved at "file://C:OMddeDebugBuildLog.htm"
dde - 0 error(s), 0 warning(s)
------ Build started: Project: debug, Configuration: Debug Win32 ------
debug - up-to-date.
Build log was saved at "file://C:OMdebugDebugBuildLog.htm"
debug - 0 error(s), 0 warning(s)
------ Build started: Project: dialogs, Configuration: Debug Win32 ------
dialogs - up-to-date.
Build log was saved at "file://C:OMdialogsDebugBuildLog.htm"
dialogs - 0 error(s), 0 warning(s)
------ Build started: Project: editor, Configuration: Debug Win32 ------
editor - up-to-date.
Build log was saved at "file://C:OMeditorDebugBuildLog.htm"
editor - 0 error(s), 0 warning(s)
------ Build started: Project: ex, Configuration: Debug Win32 ------
ex - up-to-date.
Build log was saved at "file://C:OMexDebugBuildLog.htm"
ex - 0 error(s), 0 warning(s)
------ Build started: Project: ext, Configuration: Debug Win32 ------
ext - up-to-date.
Build log was saved at "file://C:OMextDebugBuildLog.htm"
ext - 0 error(s), 0 warning(s)
------ Build started: Project: extNA, Configuration: Debug Win32 ------
extNA - up-to-date.
Build log was saved at "file://C:OMextNADebugBuildLog.htm"
extNA - 0 error(s), 0 warning(s)
------ Build started: Project: extSTATS, Configuration: Debug Win32 ------
extSTATS - up-to-date.
Build log was saved at "file://C:OMextSTATSDebugBuildLog.htm"
extSTATS - 0 error(s), 0 warning(s)
------ Build started: Project: graphics, Configuration: Debug Win32 ------
graphics - up-to-date.
Build log was saved at "file://C:OMgraphicsDebugBuildLog.htm"
graphics - 0 error(s), 0 warning(s)
------ Build started: Project: gui, Configuration: Debug Win32 ------
gui - up-to-date.
Build log was saved at "file://C:OMguiDebugBuildLog.htm"
gui - 0 error(s), 0 warning(s)
------ Build started: Project: ieee, Configuration: Debug Win32 ------
ieee - up-to-date.
Build log was saved at "file://C:OMieeeDebugBuildLog.htm"
ieee - 0 error(s), 0 warning(s)
------ Build started: Project: io, Configuration: Debug Win32 ------
io - up-to-date.
Build log was saved at "file://C:OMioDebugBuildLog.htm"
io - 0 error(s), 0 warning(s)
------ Build started: Project: math, Configuration: Debug Win32 ------
math - up-to-date.
Build log was saved at "file://C:OMmathDebugBuildLog.htm"
math - 0 error(s), 0 warning(s)
------ Build started: Project: mlfun, Configuration: Debug Win32 ------
mlfun - up-to-date.
Build log was saved at "file://C:OMmlfunDebugBuildLog.htm"
mlfun - 0 error(s), 0 warning(s)
------ Build started: Project: omtplink, Configuration: Debug Win32 ------
omtplink - up-to-date.
Build log was saved at "file://C:OMomtplinkDebugBuildLog.htm"
omtplink - 0 error(s), 0 warning(s)
------ Build started: Project: panes, Configuration: Debug Win32 ------
panes - up-to-date.
Build log was saved at "file://C:OMpanesDebugBuildLog.htm"
panes - 0 error(s), 0 warning(s)
------ Build started: Project: str, Configuration: Debug Win32 ------
str - up-to-date.
Build log was saved at "file://C:OMstrDebugBuildLog.htm"
str - 0 error(s), 0 warning(s)
------ Build started: Project: allocate, Configuration: Debug Win32 ------
allocate - up-to-date.
Build log was saved at "file://C:OMallocateDebugBuildLog.htm"
allocate - 0 error(s), 0 warning(s)
------ Build started: Project: om, Configuration: Debug Win32 ------
Linking...(Intel C++ Environment)
Fatal error cannot open "ipps.lib"
Build log was saved at "file://C:OMDebugBuildLog.htm"
Om - 2 error(s), 0 warning(s)
---------------------- Done ----------------------
Build: 20 succeeded, 1 failed, 0 skipped
JenniferJ
"xilink: error: problem during multi-file ...." doesn't mean much here. If you resolve the other error "Fatal error cannot open "ipps.lib"", my guess is this one will go away. (you just need to add the lib directory of "ipps.lib" to your link property.)
xilink calls link.exe to do some work. If link.exe returns error, xilink will display an error, but xilink doesn't the detail of the error from "link.exe".
But xilink should only display the error once.
Jennifer
