Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Android SDK App Crash - null object reference
tangk
Environment: - Ver: ICS 4.1.1 - ICS-Conferece - Do not use mixing. # log cat 2019-02-11 13:45:26.365 3645-3871/? E/ConnectivityService: RemoteException caught trying to send a callback msg for NetworkRequest [ LISTEN id=4935, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED] ] 2019-02-11 13:45:26.367 3645-3871/? E/ConnectivityService: RemoteException caught trying to send a callback msg for NetworkRequest [ LISTEN id=4936, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED] ] 2019-02-11 13:45:41.155 8203-8401/com.saeha.ezview.Dev E/AndroidRuntime: FATAL EXCEPTION: pool-5-thread-2 Process: com.saeha.ezview.Dev, PID: 8203 java.lang.NullPointerException: Attempt to invoke virtual method 'void com.intel.webrtc.conference.Subscription.onStatusUpdated(com.intel.webrtc.base.MediaConstraints$TrackKind, boolean)' on a null object reference at com.intel.webrtc.conference.ConferenceClient.lambda$onStreamUpdated$15(ConferenceClient.java:723) at com.intel.webrtc.conference.-$$Lambda$ConferenceClient$aWl5wjEHeXZzvSUNQcID27_Orgo.run(Unknown Source:6) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636) at java.lang.Thread.run(Thread.java:764) 2019-02-11 13:45:41.157 8203-8354/com.saeha.ezview.Dev E/AndroidRuntime: FATAL EXCEPTION: pool-5-thread-1 Process: com.saeha.ezview.Dev, PID: 8203 java.lang.NullPointerException: Attempt to invoke virtual method 'void com.intel.webrtc.conference.Subscription.onStatusUpdated(com.intel.webrtc.base.MediaConstraints$TrackKind, boolean)' on a null object reference at com.intel.webrtc.conference.ConferenceClient.lambda$onStreamUpdated$15(ConferenceClient.java:723) at com.intel.webrtc.conference.-$$Lambda$ConferenceClient$aWl5wjEHeXZzvSUNQcID27_Orgo.run(Unknown Source:6) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636) at java.lang.Thread.run(Thread.java:764) 2019-02-11 13:45:41.259 3645-3871/? E/ConnectivityService: RemoteException caught trying to send a callback msg for NetworkRequest [ LISTEN id=4942, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] 2019-02-11 13:45:41.275 3645-3871/? E/ConnectivityService: RemoteException caught trying to send a callback msg for NetworkRequest [ REQUEST id=4941, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] 2019-02-11 13:45:41.284 3645-3871/? E/ConnectivityService: RemoteException caught trying to send a callback msg for NetworkRequest [ LISTEN id=4939, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED] ] 2019-02-11 13:45:41.288 3645-3871/? E/ConnectivityService: RemoteException caught trying to send a callback msg for NetworkRequest [ LISTEN id=4940, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED] ] # Crash Source - ConferenceClient.class - line 656: while(!pcChannel.stream.id().equals(id) && !pcChannel.key.equals(id)); - line 663: pcChannel.subscription.onStatusUpdated(trackKind, active); It occurs randomly when a new stream is added or removed.
Jianjun_Z_Intel
Thanks for reporting this issue. You may track its status here.
tangk
Occurs when the stream is updated before receiving subscribe method call results.
