Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Android --java.lang.IllegalArgumentException--error:rootEglBase = new EglBase();
allen_w_
03-24 02:50:05.838 3948-3948/com.example.root.myapplication E/AndroidRuntime: FATAL EXCEPTION: main
        Process: com.example.root.myapplication, PID: 3948
        java.lang.RuntimeException: Unable to start activity ComponentInfo{com.example.root.myapplication/com.example.root.myapplication.SampleActivity}: java.lang.IllegalArgumentException
        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2184)
        at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2233)
        at android.app.ActivityThread.access$800(ActivityThread.java:135)
        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1196)
        at android.os.Handler.dispatchMessage(Handler.java:102)
        at android.os.Looper.loop(Looper.java:136)
        at android.app.ActivityThread.main(ActivityThread.java:5001)
        at java.lang.reflect.Method.invokeNative(Native Method)
        at java.lang.reflect.Method.invoke(Method.java:515)
        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:785)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:601)
        at dalvik.system.NativeStart.main(Native Method)
        Caused by: java.lang.IllegalArgumentException
        at com.google.android.gles_jni.EGLImpl._eglCreateContext(Native Method)
        at com.google.android.gles_jni.EGLImpl.eglCreateContext(EGLImpl.java:54)
        at com.intel.webrtc.base.EglBase.createEglContext(EglBase.java:283)
        at com.intel.webrtc.base.EglBase.<init>(EglBase.java:101)
        at com.intel.webrtc.base.EglBase.<init>(EglBase.java:88)
        at com.example.root.myapplication.SampleActivity.createUI(SampleActivity.java:154)
        at com.example.root.myapplication.SampleActivity.onCreate(SampleActivity.java:141)
        at android.app.Activity.performCreate(Activity.java:5231)
        at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1087)
        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2148)
03-24 02:50:09.668 3948-3962/com.example.root.myapplication D/dalvikvm: GC_FOR_ALLOC freed 140K, 6% free 3250K/3456K, paused 44ms, total 44ms
03-24 02:55:06.278 3948-3948/? I/Process: Sending signal. PID: 3948 SIG: 9
SampleActivity.java:154:
private void createUI() throws WoogeenException {
rootEglBase = new EglBase();//---ln154
SampleActivity.java:141:
createUI();
Chunbo_H_Intel1
Hi Allen,
We need more information to analyze this exception. Could you provide how you did this to reproduce this exception?
Information about phone module and OS version will also be helpful.
Thanks!
