Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Audio only?
Det_O_
is it possible to create a native app (android + ios) that uses only audio communication?
I've been fiddling with the native apps p2p examples source code and I also had a look to the user guides but I don't see how to enable only (from start) the audio communication.
My idea is an app for only voice without requiring access to the camera. I have read about some methods to disable the video, but I would like to start wihout requiring camera permissions from the start.
is this possible with these client SDKs?
Chunbo_H_Intel1
Yes, sure. You can disable the video track when you use the API to create the local stream before publishing it.
Thanks!
dayinfinite
But there is only audio stream, it will fail when merging
