Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Edge: 'createDataChannel' is not supported
Florian_P_
On Edge woogeen.sdk.js throws the following exception
ERROR: Failed to create SendDataChannel, exception: Object doesn't support property or method 'createDataChannel'
This happens when woogeen tries to execute RTCPeerconnection.createDataChannel. I found out that this method isn't supported under Edge. Are there any plans to add a polyfill for Edge to solve this problem or is there already a solution?
Lei_Z_Intel1
Yes, data channel is not supported, will consider adding this next half of this year. Thanks for your patience.
