Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Error while starting server and connection v3.3
Bipin_Kesharwani
I am facing following error after installing Intel CS for WebRTC 3.3 on CentOS Linux release 7.3.1611 (Core)
$ bin/start-all.sh
starting nuve, stdout -> /home/bipin/Release-v3.3/logs/woogeen-nuve.stdout
starting cluster-manager, stdout -> /home/bipin/Release-v3.3/logs/woogeen-cluster-manager.stdout
2017-03-09 11:17:44.950  - INFO: AmqpClient - Connecting to rabbitMQ server: { host: 'localhost', port: 5672 }
2017-03-09 11:17:44.967  - INFO: AmqpClient - Connection to rabbitMQ server error { [Error: connect ECONNREFUSED 127.0.0.1:5672]
  code: 'ECONNREFUSED',
  errno: 'ECONNREFUSED',
  syscall: 'connect',
  address: '127.0.0.1',
  port: 5672 }
==On same machine I am getting following error on Firefox 45.7============
Run SocketIO sample!! localhost:3001:43:9
POST
XHR
http://localhost:3001/createToken/ [HTTP/1.1 503 Service Unavailable 5ms]
ERROR: server connection failed: invalid token woogeen.sdk.js:8:11752
What could be reason ? Probably I am missing something, please help.
Thank you.
Li__Guangming
I used the 3.3 version also have this problem, some people know how to solve?
Lei_Z_Intel1
Have you run init-all.sh --deps firstly?
Li__Guangming
Already running init-all.sh --deps
Naresh_R_1
Check if rabbitmq-server started
service rabbitmq-server status
Naresh
Li__Guangming
[root@localhost bin]# service rabbitmq-server status
Status of node rabbit@localhost ...
[{pid,2731},
 {running_applications,
     [{rabbitmq_management,"RabbitMQ Management Console","3.6.5"},
      {rabbitmq_web_dispatch,"RabbitMQ Web Dispatcher","3.6.5"},
      {webmachine,"webmachine","1.10.3"},
      {mochiweb,"MochiMedia Web Server","2.13.1"},
      {rabbitmq_management_agent,"RabbitMQ Management Agent","3.6.5"},
      {rabbit,"RabbitMQ","3.6.5"},
      {os_mon,"CPO  CXC 138 46","2.2.14"},
      {ssl,"Erlang/OTP SSL application","5.3.3"},
      {public_key,"Public key infrastructure","0.21"},
      {crypto,"CRYPTO version 2","3.2"},
      {amqp_client,"RabbitMQ AMQP Client","3.6.5"},
      {rabbit_common,[],"3.6.5"},
      {inets,"INETS  CXC 138 49","5.9.8"},
      {mnesia,"MNESIA  CXC 138 12","4.11"},
      {compiler,"ERTS  CXC 138 10","4.9.4"},
      {xmerl,"XML parser","1.3.6"},
      {syntax_tools,"Syntax tools","1.6.13"},
      {asn1,"The Erlang ASN1 compiler version 2.0.4","2.0.4"},
      {ranch,"Socket acceptor pool for TCP protocols.","1.2.1"},
      {sasl,"SASL  CXC 138 11","2.3.4"},
      {stdlib,"ERTS  CXC 138 10","1.19.4"},
      {kernel,"ERTS  CXC 138 10","2.16.4"}]},
 {os,{unix,linux}},
 {erlang_version,
     "Erlang R16B03-1 (erts-5.10.4) [source] [64-bit] [smp:4:4] [async-threads:64] [hipe] [kernel-poll:true]\n"},
 {memory,
     [{total,114106384},
      {connection_readers,510072},
      {connection_writers,280552},
      {connection_channels,766200},
      {connection_other,850968},
      {queue_procs,917880},
      {queue_slave_procs,0},
      {plugins,2265704},
      {other_proc,19315168},
      {mnesia,131664},
      {mgmt_db,6076208},
      {msg_index,67336},
      {other_ets,2002664},
      {binary,47345696},
      {code,27158116},
      {atom,992409},
      {other_system,5425747}]},
 {alarms,[]},
 {listeners,[{clustering,25672,"::"},{amqp,5672,"::"}]},
 {vm_memory_high_watermark,0.4},
 {vm_memory_limit,1547108352},
 {disk_free_limit,50000000},
 {disk_free,31858630656},
 {file_descriptors,
     [{total_limit,924},
      {total_used,20},
      {sockets_limit,829},
      {sockets_used,18}]},
 {processes,[{limit,1048576},{used,679}]},
 {run_queue,0},
 {uptime,21399},
 {kernel,{net_ticktime,60}}]
Lei_Z_Intel1
Seems RabbitMQ works well. Any firewall policy prevent you access localhost:5672?
Li__Guangming
Has closed the firewall。。。。
Lei_Z_Intel1
Seems Guangming's issue is about remote accessing rabbitMQ with guest user, which has been resolved in topic https://software.intel.com/en-us/forums/intel-collaboration-suite-for-webrtc/topic/720316.
Hi.  Bipin Kesharwani
Has your problem resolved with single MCU deployment? Have you run init-all.sh --deps to make sure rabbitMQ started before start-all.sh?
Best wishes,
Zhai Lei
Bipin_Kesharwani
Thanks all for the help and sorry for very late reply. Rabbitmq was not present in the system, installing it solved the issue.
Bipin Kesharwani
