Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
GW-2.8.1: libnice.so.10 is missing
JHorn4
Hi Chunbo,
after installing and first starting GW package into a separate directory, I got following error message:
Error: libnice.so.10: cannot open shared object file: No such file or directory
It seems that that library is not shipping with GW package, although its part of the MCU package. After manually copying to the lib directory at GW all seems to work fine.
Is this a knwon feature/error or I am doing something wrong?
Chunbo_H_Intel1
You're right. This is a known issue. We will fix this next release.
Thanks!
Chunbo_H_Intel1
Also you can install libnice10 by executing “sudo apt-get install libnice10” on Ubuntu system.
Thanks!
