Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Has anyone try to package delegates with Rx? (ios 4.2SDK)
JJ_Lin
I was trying to extend OWTConferenceClientDelegate to rx DelegateProxy but I keep got nil while setCurrentDelegate.
The error said that "mutex lock failed: Invalid argument" in libc++.tbd
Is there anyway to solve this?
Is this error means that the thread which static lib runs in are private or unsafe?
請問是否有人嘗試將ios sdk裡的delegates事件封裝成rx的delegateProxy? 在封裝之後調用rx的delegateProxy事件例如OWTConferenceClientDelegate的conferenceClient:didAddStream: 時會產生mutex lock failed: Invalid argument錯誤
想詢問有人成功將delegates封裝成rx嗎?
import RxSwift
import RxCocoa
private class RxOWTConferenceClientDelegateProxy: DelegateProxy<OWTConferenceClient, OWTConferenceClientDelegate>, DelegateProxyType, OWTConferenceClientDelegate {
    public weak private (set) var controller: OWTConferenceClient?
    public init(controller: ParentObject) {
        self.controller = controller
        super.init(parentObject: controller, delegateProxy: RxOWTConferenceClientDelegateProxy.self)
    static func registerKnownImplementations() {
        self.register { RxOWTConferenceClientDelegateProxy(controller: $0) }
    static func currentDelegate(for object: OWTConferenceClient) -> OWTConferenceClientDelegate? {
        return object.delegate
    static func setCurrentDelegate(_ delegate: OWTConferenceClientDelegate?, to object: OWTConferenceClient) {
        object.delegate = delegate     <<<<<<< ERROR happens to this line.
extension Reactive where Base: OWTConferenceClient {
    public var delegate: DelegateProxy<OWTConferenceClient, OWTConferenceClientDelegate> {
        return RxOWTConferenceClientDelegateProxy.proxy(for: base)
    func join(token: String) -> Single<OWTConferenceInfo> {
        return Single<OWTConferenceInfo>.create { single in
            self.base.join(withToken: token,
                      onSuccess: { (info) in
                        single(.success(info))
                        return
                      onFailure: { (error) in
                        single(.error(error))
                        return
            return Disposables.create()
    func doPublish(constraints: OWTStreamConstraints) -> Single<OWTConferencePublication> {
        return Single<OWTConferencePublication>.create { single in
            var err: NSError?
            let localStream = OWTLocalStream(constratins: constraints, error: &err)
            if err != nil { single(.error(err!)) }
            self.base.publish(localStream,
                              with: nil,
                              onSuccess: { single(.success($0))
                              onFailure: { single(.error($0))
    func leave() -> Single<Void> {
        return Single<Void>.create { single in
            self.base.leaveWith(
                onSuccess: { single(.success(()))
    public var didAddStream: Observable<OWTRemoteStream> {
        return delegate.methodInvoked(#selector(OWTConferenceClientDelegate.conferenceClient(_:didAdd:) as ((OWTConferenceClientDelegate) -> (OWTConferenceClient, OWTRemoteStream) -> Void)?))
            .observeOn(MainScheduler.instance)
            .map { $0[1] as! OWTRemoteStream }
    public var didAddParticipant: Observable<OWTConferenceParticipant> {
        return delegate.methodInvoked(#selector(OWTConferenceClientDelegate.conferenceClient(_:didAdd:) as ((OWTConferenceClientDelegate) -> (OWTConferenceClient, OWTConferenceParticipant) -> Void)?))
            .map { $0[1] as! OWTConferenceParticipant }
