Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
In android SDK,why LocalCameraStreamParameters.setResolution has no effect
张_进_
1. I use the method which name is LocalCameraStreamParameters.setResolution to set several different resolutions.But it doesn't work
2.How does MCU 3.0 rotate video, and the method LocalCameraStreamParameters.setDisplayOrientation(context), it doesn‘t work too.
He_Z_Intel
Hi, could you please elaborate the reproduce procedure? Thanks
张_进_
LocalCameraStreamParameters msp = new LocalCameraStreamParameters(
						true, true);
				PublishOptions option = new PublishOptions();
//				msp.setCamera(CameraType.FRONT);
				if (rate == 3) {
					String resolution = ConfigUtil.getInstance().getResolution();
					 if(!TextUtils.isEmpty(resolution)){
						switch (Integer.parseInt(resolution.split("x")[0])) {
						case 320:
							msp.setResolution(320, 240);
							maximumVideoBandwidth = 300;
							option.setMaximumVideoBandwidth(maximumVideoBandwidth);
							option.setMaximumAudioBandwidth(50);
							break;
						case 640:
							msp.setResolution(640, 480);
							maximumVideoBandwidth = 600;
							option.setMaximumAudioBandwidth(100);
							break;
						case 750:
							msp.setResolution(750, 540);
							maximumVideoBandwidth = 703;
							option.setMaximumAudioBandwidth(117);
							break;
						case 480:
							msp.setResolution(480, 360);
							maximumVideoBandwidth = 450;
							option.setMaximumAudioBandwidth(75);
							break;
						case 360:
							msp.setResolution(360, 240);
							maximumVideoBandwidth = 338;
							option.setMaximumAudioBandwidth(56);
							break;
						case 180:
							msp.setResolution(180, 120);
							maximumVideoBandwidth = 168;
							option.setMaximumAudioBandwidth(28);
							break;
						case 1024:
						default:
							msp.setResolution(1024, 768);
							maximumVideoBandwidth = 960;
							break;
张_进_
Feeling a little bit of the effect, the effect is not very obvious
YanbinZ_Intel
1. Please make sure your connection network bandwidth is sufficient to transfer high resolutions' video
2. make sure the resolution is supported by your test phone camera.
3. Please close the previous stream  then create new resolution camera stream .
