Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Memory Leak Error
Naresh_R_1
Dear Team,
I found the below error when my mcu crashed, please let me know what could be the reason'
2019-08-28 05:45:47.031  - INFO: NodeManager - Node webrtc-c167bb2896fe2cf8a4bb@172.31.14.68_43 is closed on unexpected code: null
2019-08-28 10:42:34.936  - INFO: NodeManager - Node webrtc-c167bb2896fe2cf8a4bb@172.31.14.68_107 is closed on unexpected code: null
2019-08-29 10:34:11.481  - INFO: NodeManager - Node webrtc-c167bb2896fe2cf8a4bb@172.31.14.68_190 is closed on unexpected code: null
2019-09-03 07:24:01.439  - INFO: NodeManager - Node webrtc-c167bb2896fe2cf8a4bb@172.31.14.68_355 is closed on unexpected code: null
2019-09-03 09:13:24.622  - INFO: NodeManager - Node webrtc-c167bb2896fe2cf8a4bb@172.31.14.68_370 is closed on unexpected code: null
2019-09-03 09:36:39.087  - INFO: NodeManager - Node webrtc-c167bb2896fe2cf8a4bb@172.31.14.68_381 is closed on unexpected code: null
2019-09-03 11:59:55.262  - INFO: NodeManager - Node webrtc-c167bb2896fe2cf8a4bb@172.31.14.68_410 is closed on unexpected code: null
2019-09-08 13:37:10.257  - INFO: LoadCollector - To stop load collector.
internal/child_process.js:313
    throw errnoException(err, 'spawn');
Error: spawn ENOMEM
    at ChildProcess.spawn (internal/child_process.js:313:11)
    at exports.spawn (child_process.js:508:9)
    at Object.exports.execFile (child_process.js:218:15)
    at Object.exports.exec (child_process.js:148:18)
    at Timeout.<anonymous> (/home/centos/Release-v4.2/webrtc_agent/loadCollector.js:1:1222)
    at ontimeout (timers.js:498:11)
    at tryOnTimeout (timers.js:323:5)
    at Timer.listOnTimeout (timers.js:290:5)
[root@ip-172-31-14-68 logs]# cat webrtc-c167bb2896fe2cf8a4bb@172.31.14.68_648.log
Naresh
Li_C_Intel
Have you checked which process consumed too much memory? E.g. using 'top command.
