Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Multiple portal nodes with single hostname
palla__muralidhar
We are trying to deploy multiple portal nodes under single hostname, is it possible to do ?  will put LB infront if yes, i think session stickyness problem may occur too .
OR we need to maintain multiple hostnames for multiple portal nodes?
Environment : Ubuntu 14.04
Version : 3.4.1
palla__muralidhar
Any updates?
palla__muralidhar
Hi Team,
Any updates on this?
Can we put SSL Termination at LB instead of backend application server ( for portals)?  we tried to put ssl=false at portal.toml and pass ssl requests through LB, but it didnt worked as portal application is serving http requests only.
any inputs here?
Qiujiao_W_Intel
We have a inner scheduling mechanism for portal which may conflict with LB, so currently it cannot work, we will consider your request
