Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
RTMP STREAM INPUT
ANIL_K_3
Dear Support Team,
Is there any possibilty to input the rtmp stream or webrtc data channel stream to Intel MCU Forward or Mix stream .
Example : For ongoing Mix or Forward stream stream i need to add rtmp stream or webrtc data channel stream to that  .
Is it Possible or do you consider this feature as your road map
Yang__Jeff
In "Building a scalable and hybrid communication cloud with Intel CS for WebRTC" slides by WenJie Zhang, it says RTMP input is supported, Can you confirm if RTMP input is actually supported? If not, can you share if Intel has plan to support it.
