Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
The android apk in the sdk are failed to connect to server
eric_h_1
The servers for woogeenconference.apk
basic server:http://61.152.239.56:3001/
manager:http://61.152.239.56:3000/
are failed to connect Socket.io connect failed.
I use the SDK CS_WebRTC_Client_SDK_Android.v3.0
and the server for woogeenp2p.apk
http:61.152.239.56:8095/ is failed to login
log for woogeenconference.apk >>>>>>>>>>>>>>>>>>>>>>>>>>>>
03-17 15:27:02.841 D/WooGeen-Activity(12416): token is eyJ0b2tlbklkIjoiNTZlYTViNGVjMDg0OWVkMzE1NzE3NGJiIiwiaG9zdCI6IjYxLjE1Mi4yMzkuNTY6ODAiLCJzZWN1cmUiOnRydWUsInNpZ25hdHVyZSI6Ik1XVTNNbU5oTTJRek1qTmpNbU0xTXpJMU1qZGhZV0ZqTUdFeVpqQTJNVEV6TVdZNE5qVmtPRGsxWkRjek1XRmlaV0kyWmpObFptRmlNakZsWmpJeU1nPT0ifQ==
03-17 15:27:02.841 D/WooGeen-ConferenceClient(12416): Join a conference.
03-17 15:27:02.841 D/WooGeen-SocketClient(12416): Token is {"tokenId":"56ea5b4ec0849ed3157174bb","host":"61.152.239.56:80","secure":true,"signature":"MWU3MmNhM2QzMjNjMmM1MzI1MjdhYWFjMGEyZjA2MTEzMWY4NjVkODk1ZDczMWFiZWI2ZjNlZmFiMjFlZjIyMg=="}
03-17 15:27:02.841 D/WooGeen-SocketClient(12416): Socket thread is started.
03-17 15:27:03.181 E/WooGeen-SocketClient(12416): Socket.IO is not connected:com.github.nkzawa.engineio.client.EngineIOException: xhr poll error
03-17 15:27:03.191 D/WooGeen-SocketClient(12416): SocketIOClient Disconnected.
log for woogeenp2p.apk >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
03-17 15:29:20.061 D/WooGeen-Activity(12737): Failed to connect server:Socket.IO reports connect to signaling server failed.
Chunbo_H_Intel1
Hi Eric,
Could you tell us where you connected your Android phone to the server? I mean, using 4G/3G, or behind a firewall.
Another thing is that: Have you tried to connect to the server with Chrome, in order to make sure the server work correctly.
Thanks!
eric_h_1
both 4G and wifi are failed to connect to server. The token is successfully get,
but it failed in the socket.io-client.jar
Chunbo_H_Intel1
Have you used Chrome to check the availability of your MCU server?
Thanks!
eric_h_1
HI
We do not setup a MCU server, but use the default server provided in the SDK samples
Chunbo_H_Intel1
We do not provide public service of conference. You will have to setup your own server.
Thanks!
Michael_C_14
Hi Chunbo H,
I setup own MCU server but still receive following error:
08-01 18:56:48.662 25165-25184/com.intel.webrtc.conference.sample D/WooGeen-SocketClient: Token is {"tokenId":"579f3901953baf790873c314","host":"X.X.X.X:8080","secure":true,"signature":"NjI5ZDE2OTY3ZmVjODVlY2M3YzJmNGM1YTVkODczYjNhN2E3ZDBhYzIwOWQ1MzI5ODFhMWY3ZDkwM2Y3MDVmOQ=="}
08-01 18:56:48.672 25165-25719/com.intel.webrtc.conference.sample D/WooGeen-SocketClient: Socket thread is started.
08-01 18:56:48.912 25165-25732/com.intel.webrtc.conference.sample E/WooGeen-SocketClient: Socket.IO is not connected:io.socket.engineio.client.EngineIOException: xhr poll error
08-01 18:56:48.912 25165-25732/com.intel.webrtc.conference.sample D/WooGeen-SocketClient: SocketIOClient Disconnected.
Pls, give me your advice?
Chunbo_H_Intel1
Hi Michael,
Which version of MCU are you using now? And, can you connect to the MCU with a latest Chrome? We want to make sure that MCU works normally on your side first.
hua_c_
it works when you make "ssl=false" in file controller.toml
i think the key problem is that android sdk doesn't support ssl connection.
if i am right, please fix it.
Michael_C_14
Hi Chunbo,
I use CS_WebRTC_Conference_Server_MCU.v3.1.1. I fixed this issue on Android by change security config from "true" to "false" but not enough. I'm find the way to run HTTPS on 8080 port. Who can give me advices?
Chunbo_H_Intel1
Android SDK does not support the self-signed certificate. You will need a CA issued digital certificate to run SSL on Android SDK.
Thanks!
